# UVM Constrains inside a sequence are ignored
**URL:** <https://verificationacademy.com/forums/t/uvm-constrains-inside-a-sequence-are-ignored/40485>\
**Tags:** systemverilog-uvm, UVM, constraint-randomization, sequence, sequence-item\
**Created:** [June 3, 2022, 4:46pm UTC](https://verificationacademy.com/forums/t/uvm-constrains-inside-a-sequence-are-ignored/40485 "2022-06-03T16:46:10Z")\
**Showing post:** 2
**Post date:** [June 3, 2022, 5:34pm UTC](https://verificationacademy.com/forums/t/uvm-constrains-inside-a-sequence-are-ignored/40485/2 "2022-06-03T17:34:26Z")
_In reply to [HelenLG](https://verificationacademy.com/forums/t/uvm-constrains-inside-a-sequence-are-ignored/40485):_
Your contraint is in the wrong place. You have to use an inline constraint while randomizing the seq\_item, like this
```verilog
  virtual task body();
    `uvm_info(get_type_name(),$sformatf("Sequence randomize with %s", item.mode.name()), UVM_NONE)
    start_item(item);
    if ( !item.randomize()with {item.mode == NORMAL_OP;})
      `uvm_error(get_type_name(), "Failed to randomize transaction")
    finish_item(item);
  endtask : body
Adding the constraint as a seperate constraint as you did is limited to the usage in the seq\_item class.
_[View the full topic](https://verificationacademy.com/forums/t/uvm-constrains-inside-a-sequence-are-ignored/40485)._
