# Uvm\_config\_db / uvm\_resource\_db for registering virtual interfaces
**URL:** <https://verificationacademy.com/forums/t/uvm-config-db-uvm-resource-db-for-registering-virtual-interfaces/33179>\
**Tags:** virtual-interface, UVM, uvm\_config\_db\
**Created:** [June 6, 2017, 1:53pm UTC](https://verificationacademy.com/forums/t/uvm-config-db-uvm-resource-db-for-registering-virtual-interfaces/33179 "2017-06-06T13:53:03Z")\
**Showing post:** 15
**Author:** ![Vperrin](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/v/eada6e/32.png) [@Vperrin](https://verificationacademy.com/forums/u/Vperrin)\
**Post date:** [June 7, 2017, 12:46pm UTC](https://verificationacademy.com/forums/t/uvm-config-db-uvm-resource-db-for-registering-virtual-interfaces/33179/15 "2017-06-07T12:46:24Z")
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/uvm-config-db-uvm-resource-db-for-registering-virtual-interfaces/33179/14):_
Yes this is the build\_phase of the env. I don’t see any problem for the config\_db but I still have the issue with resource\_db.
Ok you can put different names in the resource\_db in your top module (“apb\_tx”, “apb\_rx”) but in the agent build\_phase when you call resource\_db you don’t know which string to provide for the name
_[View the full topic](https://verificationacademy.com/forums/t/uvm-config-db-uvm-resource-db-for-registering-virtual-interfaces/33179)._
