# Uvm\_config\_db / uvm\_resource\_db for registering virtual interfaces
**URL:** <https://verificationacademy.com/forums/t/uvm-config-db-uvm-resource-db-for-registering-virtual-interfaces/33179>\
**Tags:** virtual-interface, UVM, uvm\_config\_db\
**Created:** [June 6, 2017, 1:53pm UTC](https://verificationacademy.com/forums/t/uvm-config-db-uvm-resource-db-for-registering-virtual-interfaces/33179 "2017-06-06T13:53:03Z")\
**Showing post:** 12
**Post date:** [June 6, 2017, 8:49pm UTC](https://verificationacademy.com/forums/t/uvm-config-db-uvm-resource-db-for-registering-virtual-interfaces/33179/12 "2017-06-06T20:49:00Z")
_In reply to [Vperrin](https://verificationacademy.com/forums/t/uvm-config-db-uvm-resource-db-for-registering-virtual-interfaces/33179/11):_
What do you mean with the ‘same class’. An interface is not a class. It is a SV Interface. And a virtual interface uses the SV Interface as a type.
I understood you have 2 Interfaces of the same type. One is stored in the config\_db/resource\_db under the Name “apb\_tx” and the other one under the name “apb\_rx”.
_[View the full topic](https://verificationacademy.com/forums/t/uvm-config-db-uvm-resource-db-for-registering-virtual-interfaces/33179)._
