# Uvm\_config\_db get from inside uvm\_sequence
**URL:** <https://verificationacademy.com/forums/t/uvm-config-db-get-from-inside-uvm-sequence/35696>\
**Category:** UVM\
**Tags:** UVM, uvm\_config\_db\
**Created:** [February 3, 2019, 4:28am UTC](https://verificationacademy.com/forums/t/uvm-config-db-get-from-inside-uvm-sequence/35696 "2019-02-03T04:28:48Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![atalur](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/a/f19dbf/32.png) [@atalur](https://verificationacademy.com/forums/u/atalur)\
**Post date:** [February 3, 2019, 4:28am UTC](https://verificationacademy.com/forums/t/uvm-config-db-get-from-inside-uvm-sequence/35696/1 "2019-02-03T04:28:48Z")
</div>
How could one do a get from inside the sequence class? Sequences are not part of the component hierarchy. I have seen it being used as so -
uvm\_config\_db #(something):: get(null, get\_full\_name(), “”, \_\_\_)
what would be the equivalent set()? Would global wildcard set(null, “\*”, “”, \_\_\_) work?
**Post date:** [February 3, 2019, 7:34am UTC](https://verificationacademy.com/forums/t/uvm-config-db-get-from-inside-uvm-sequence/35696/2 "2019-02-03T07:34:46Z")
</div>
_In reply to [kernalmode1](https://verificationacademy.com/forums/t/uvm-config-db-get-from-inside-uvm-sequence/35696):_
[https://verificationacademy.com/cookbook/config/configuringsequences](https://verificationacademy.com/cookbook/config/configuringsequences)
**Post date:** [February 3, 2019, 7:45am UTC](https://verificationacademy.com/forums/t/uvm-config-db-get-from-inside-uvm-sequence/35696/3 "2019-02-03T07:45:44Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/uvm-config-db-get-from-inside-uvm-sequence/35696/2):_
Ah, thanks!
