# Uvm\_algorithmic\_comparator
**URL:** <https://verificationacademy.com/forums/t/uvm-algorithmic-comparator/28784>\
**Category:** UVM\
**Tags:** UVM\
**Created:** [September 3, 2013, 12:18pm UTC](https://verificationacademy.com/forums/t/uvm-algorithmic-comparator/28784 "2013-09-03T12:18:40Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![sachin4a0](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/d9b06d/32.png) [@sachin4a0](https://verificationacademy.com/forums/u/sachin4a0)\
**Post date:** [September 3, 2013, 12:18pm UTC](https://verificationacademy.com/forums/t/uvm-algorithmic-comparator/28784/1 "2013-09-03T12:18:40Z")
</div>
Hello Mavens,
Can anyone explain me how to use uvm\_algorithmic\_comparator in scoreboard, I tried myself with the following code for comparing the data of two different transaction classes such as after\_item and before\_item.
Can anybody guide me where I’ve gone wrong.
```auto
class scoreboard extends uvm_algorithmic_comparator#(before_item, after_item, after_item);
 						 // before after transformer
 `uvm_component_utils(scoreboard)
  uvm_tlm_analysis_fifo #(after_item) before_fifo; // from master_uvc
  uvm_tlm_analysis_fifo #(before_item) after_fifo; // from slave_uvc
  after_item hi; // transaction class of after
  after_item hi1 = new;; // transaction class of after
  before_item pi; // transaction class of before
 function new(string name = "scoreboard", uvm_component parent, TRANSFORMER after_item);
	super.new(name, parent, "hi1");
	before_fifo = new("before_fifo", this);
	after_fifo = new("after_fifo", this);
//function after transform before handle
 function after_item transform (before_item item);
//	super.transform(item); //Dont know what to write in this function
	hi1.data = item.data;
     forever
	    before_fifo.get(pi); // getting from before_item
	    after_fifo.get(hi); // getting from after_item
	    transform(pi);
	    if(!hi.compare(hi1)) //I'm calling compare function of after transaction class which only do data comparision
		$display("DATA MISMATCH");
		$display("DATA MATCHED");
Thanks in advance
**Author:** ![gordon](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/g/3da27b/32.png) [@gordon](https://verificationacademy.com/forums/u/gordon)\
**Post date:** [September 12, 2014, 2:06am UTC](https://verificationacademy.com/forums/t/uvm-algorithmic-comparator/28784/2 "2014-09-12T02:06:30Z")
</div>
There are multiple problems with your code - refer to the reference guide for [uvm\_algorithmic\_comparator](https://verificationacademy.com/verification-methodology-reference/uvm/docs_1.1d/html/index.html) for the correct usage / see the corrected code below:
The type signature is uvm\_algorithmic\_comparator #(BEFORE,AFTER,TRANSFORMER) where TRANSFORMER should be a CLASS that contains a method with the signature ‘function AFTER transform (BEFORE b)’ i.e. which takes an object of type BEFORE and returns a transformed object of type AFTER. That class can be your scoreboard class, or some other class of your choosing.
```verilog
class scoreboard extends uvm_algorithmic_comparator#(before_item, after_item, scoreboard);
Your two fifos were the wrong way around:
```verilog
  uvm_tlm_analysis_fifo #(after_item) after_fifo;
  uvm_tlm_analysis_fifo #(before_item) before_fifo;
```verilog
  after_item hi;
  before_item pi;
Your constructor does NOT need a third argument, only the uvm\_algorithmic\_comparator constructor does (you call it with super.new()). In this example we are passing ‘this’ so that the base class can call OUR transform() method:
```verilog
  function new(string name = "scoreboard", uvm_component parent=null);
    super.new(name, parent, this);
```verilog
Note that your usage of the transform() is not strictly as intended, better to use its return value rather than have it update a class member variable. What you have does compile OK however.
```verilog
    forever
	after_fifo.get(hi);
	transform(pi);
Note that this comparator is suitable only for simple scoreboarding requirements.
