# UVM agent topology for request and response interfaces
**URL:** <https://verificationacademy.com/forums/t/uvm-agent-topology-for-request-and-response-interfaces/32762>\
**Category:** UVM\
**Tags:** virtual-interface, uvm-agent, UVM, UVM-monitor, UVM-Driver\
**Created:** [January 19, 2017, 9:51pm UTC](https://verificationacademy.com/forums/t/uvm-agent-topology-for-request-and-response-interfaces/32762 "2017-01-19T21:51:13Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![1978bubun](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/1/a87d85/32.png) [@1978bubun](https://verificationacademy.com/forums/u/1978bubun)\
**Post date:** [January 19, 2017, 9:51pm UTC](https://verificationacademy.com/forums/t/uvm-agent-topology-for-request-and-response-interfaces/32762/1 "2017-01-19T21:51:13Z")
</div>
I have a UVM agent which needs to drive request xtxns to DUT. The DUT returns request\_credit to the agent. After a while, the DUT returns a response xtxn for the previous request. I need to grab it in my monitor, and send a response credit back to the DUT from the agent.
In your opinion, what is a good way to structure this?
Option 1 : Request and response are done through two different UVM agents, each having their own driver/seqr/monitor. A virtual sequence (or some other method) communicates between them if at all needed (like, tracking outstanding responses, so that no more requests are sent etc)
Option 2. Have one agent, which has one monitor grabbing all request and response signals. There are two drivers (with corresponding sequencers). One driver drives response credit back, the other drives requests.
Option 3. Have one agent as above, one monitor, but only one driver. There are two sequencers for the resp\_credit and req\_xtxns. The drivers have virtual interface handles for both interfaces, and gets stuff from the two sequencers in parallel, and drives them on corresponding interfaces (using an extra analysis\_port and a fork-join method within run\_phase)
**Post date:** [January 21, 2017, 10:13am UTC](https://verificationacademy.com/forums/t/uvm-agent-topology-for-request-and-response-interfaces/32762/2 "2017-01-21T10:13:06Z")
</div>
_In reply to [1978bubun](https://verificationacademy.com/forums/t/uvm-agent-topology-for-request-and-response-interfaces/32762):_
I’m not sure if I understood your explanation correctly. But it looks like you have a piplelined bahavior, have you?
**Post date:** [January 23, 2017, 5:14pm UTC](https://verificationacademy.com/forums/t/uvm-agent-topology-for-request-and-response-interfaces/32762/3 "2017-01-23T17:14:31Z")
</div>
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/uvm-agent-topology-for-request-and-response-interfaces/32762/2):_
> _In reply to [1978bubun](https://verificationacademy.com/forums/t/uvm-agent-topology-for-request-and-response-interfaces/32762/2):_
I wouldn’t call it a pipelined behavior. My request and response transactions are all single flit. There is no header-data separation.
**Post date:** [January 23, 2017, 6:51pm UTC](https://verificationacademy.com/forums/t/uvm-agent-topology-for-request-and-response-interfaces/32762/4 "2017-01-23T18:51:30Z")
</div>
_In reply to [1978bubun](https://verificationacademy.com/forums/t/uvm-agent-topology-for-request-and-response-interfaces/32762/3):_
The standard UVM behavior is that to aeach request there belongs a response. After the response was send back the next request will be generated. Is this the case in your example?
