# Using sequence as event contol
**URL:** <https://verificationacademy.com/forums/t/using-sequence-as-event-contol/42961>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, Using-sequence-as-event-contol\
**Created:** [October 8, 2023, 5:08pm UTC](https://verificationacademy.com/forums/t/using-sequence-as-event-contol/42961 "2023-10-08T17:08:44Z")\
**Showing post:** 10
**Author:** ![user49](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/user49/32/1084_2.png) [@user49](https://verificationacademy.com/forums/u/user49)\
**Post date:** [October 10, 2023, 8:37pm UTC](https://verificationacademy.com/forums/t/using-sequence-as-event-contol/42961/10 "2023-10-10T20:37:48Z")
_In reply to [MICRO\_91](https://verificationacademy.com/forums/t/using-sequence-as-event-contol/42961/9):_
> As a result there is no pre-defined order of execution between the function ‘Length’ and action block.
Probably correct. However, since the void function length was put into q queue to be executed at a later point, anything to be queued in the action block may be executed next.
A tool vendor can do what he wants.
_[View the full topic](https://verificationacademy.com/forums/t/using-sequence-as-event-contol/42961)._
