# Using %p after Upcasting
**URL:** <https://verificationacademy.com/forums/t/using-p-after-upcasting/35870>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, Using-p-after-UpCasting\
**Created:** [March 20, 2019, 11:19am UTC](https://verificationacademy.com/forums/t/using-p-after-upcasting/35870 "2019-03-20T11:19:32Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![himanshuvalecha](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/h/97f17d/32.png) [@himanshuvalecha](https://verificationacademy.com/forums/u/himanshuvalecha)\
**Post date:** [March 20, 2019, 11:19am UTC](https://verificationacademy.com/forums/t/using-p-after-upcasting/35870/1 "2019-03-20T11:19:32Z")
</div>
Hello everyone ,
I have a small code ::
```verilog
module Main ;
class Base
rand bit [1:0] a ;
class Ext extends Base ;
rand bit [1:0] b;
Ext e ;
Base b ;
e = new() ;
b = e ; // Up-Casting
if ( b.randomize() ) // randomize() is Virtual
$display(" b is %p ",b);
Should the Output Ideally have 2 Properties ( a && b ) OR Only 1 ( Only a ) ??
 I tried this on different Simulators and got 2 Different Results
Thanks in advance ,
Himanshu V
**Post date:** [March 20, 2019, 4:13pm UTC](https://verificationacademy.com/forums/t/using-p-after-upcasting/35870/2 "2019-03-20T16:13:17Z")
</div>
_In reply to [himanshu valecha](https://verificationacademy.com/forums/t/using-p-after-upcasting/35870):_
The LRM defines %p for printing aggregate types as an assignment pattern. Classes are not considered aggregate types and does not define their use with assignment patterns. Some tools allow the use of %p with classes as a debugging aid, but the output is not defined. This is a tool specific issues and this forum is not for discussing those kinds of issues. Please contact your tool vendor.
