# Use \`uvm\_do macro from uvm\_test
**URL:** <https://verificationacademy.com/forums/t/use-uvm-do-macro-from-uvm-test/36287>\
**Tags:** UVM, sequence, UVM-uvm\_test, uvm\_do-macros\
**Created:** [July 12, 2019, 2:07pm UTC](https://verificationacademy.com/forums/t/use-uvm-do-macro-from-uvm-test/36287 "2019-07-12T14:07:54Z")\
**Showing post:** 4
**Post date:** [July 16, 2019, 8:23pm UTC](https://verificationacademy.com/forums/t/use-uvm-do-macro-from-uvm-test/36287/4 "2019-07-16T20:23:42Z")
_In reply to [DamianS](https://verificationacademy.com/forums/t/use-uvm-do-macro-from-uvm-test/36287/3):_
This is because the test will not generate seq\_items. It starts a sequence on a sequencer.
If the sequence is a virtual sequence it starts sequences in the agents. These (local) sequences use `uvm\_do or start\_item/finish\_item.
_[View the full topic](https://verificationacademy.com/forums/t/use-uvm-do-macro-from-uvm-test/36287)._
