# $urandom\_unsigned\_value
**URL:** <https://verificationacademy.com/forums/t/urandom-unsigned-value/35035>\
**Category:** SystemVerilog\
**Tags:** signed, urandom, SystemVerilog, randomization\
**Created:** [September 14, 2018, 3:57pm UTC](https://verificationacademy.com/forums/t/urandom-unsigned-value/35035 "2018-09-14T15:57:51Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![Mahesh\_6](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/m/ecd19e/32.png) [@Mahesh\_6](https://verificationacademy.com/forums/u/Mahesh_6)\
**Post date:** [September 14, 2018, 3:57pm UTC](https://verificationacademy.com/forums/t/urandom-unsigned-value/35035/1 "2018-09-14T15:57:51Z")
</div>
$urandom generates unsigned values. Consider the following;
1. int a1;
a1 = $urandom;
//generates both positive and negative numbers.
2. int unsigned a2;
a2 = $urandom;
//generates only positive numbers.
3. int unsigned a3;
a3 = $random;
//generates only positive numbers with ‘$random’ keyword and not ‘$urandom’.
So, in order to generate positive numbers, explicit keyword ‘unsigned’ is required. This shows that there is no much difference between $random and $urandom.
In a simpler manner, without declaring the explicit keyword, we can still generate positive numbers;
1. int a4;
a4 = $urandom\_range(200,0);
//only positive numbers.
Can we make best practice of method 4) for simiplicity ?
**Post date:** [September 14, 2018, 4:17pm UTC](https://verificationacademy.com/forums/t/urandom-unsigned-value/35035/2 "2018-09-14T16:17:14Z")
</div>
_In reply to [Mahesh K](https://verificationacademy.com/forums/t/urandom-unsigned-value/35035):_
1. is incorrect. Both $random and $urandom generate 32-bit numbers. As with any assignment, the _signed-ness_ of a value only affects sign-extension when going from a narrow signed value to a wider signed value.
If you only want to deal with positive numbers, then only use unsigned data types.
Also, do not use $random as it provides no stability or global seed control.
