# Unable to pass interface signal by reference to a task
**URL:** <https://verificationacademy.com/forums/t/unable-to-pass-interface-signal-by-reference-to-a-task/36899>\
**Category:** UVM\
**Tags:** UVM, SystemVerilog, pass-by-reference, interface\
**Created:** [December 9, 2019, 4:38am UTC](https://verificationacademy.com/forums/t/unable-to-pass-interface-signal-by-reference-to-a-task/36899 "2019-12-09T04:38:17Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![umeshr1](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/u/e9a140/32.png) [@umeshr1](https://verificationacademy.com/forums/u/umeshr1)\
**Post date:** [December 9, 2019, 4:38am UTC](https://verificationacademy.com/forums/t/unable-to-pass-interface-signal-by-reference-to-a-task/36899/1 "2019-12-09T04:38:17Z")
</div>
I am trying to pass an interface signal by reference as shown in the below code. But, I see that the simulation hangs at @posedge statement. Even though I have used ref in the compare\_freq task, it seems that the clkout value is always 0 and the simulation is stuck inside the task.
When I try to move the contents of the task inside run task, it works fine.
```verilog
interface test_probe_intf();
  logic c1_pll_clk_out;
  logic cpu_pll_clk_out;
endinterface
class pll_cfg_test extends uvm_test;
  `uvm_component_utils(pll_cfg_test)
  virtual test_probe_intf test_probe_if;
  function new(string name = "pll_cfg_test", uvm_component parent = null);
    super.new(name, parent);
  endfunction : new
    super.build_phase(phase);
    if(!uvm_config_db #(virtual test_probe_intf)::get(null, this.get_full_name(),"test_probe_if", test_probe_if)) begin
    `uvm_fatal(get_name(), "Unable to get test_probe_if handle");
  endfunction : build_phase
  task run_phase (uvm_phase phase) ;
    phase.raise_objection(this);
      compare_freq(test_probe_if.cpu_pll_clk_out,1000);
    join_none
    #20us;
	phase.drop_objection(this);
  task compare_freq (ref logic clk_out, input real expected_freq);
    real clk_out_position;
    real clk_out_next_position;
    real clk_freq;
    @(posedge clk_out);
    //$realtime in nano seconds
    clk_out_position = $realtime;
    repeat(NUMBER_OF_CYCLES_TO_COUNT)
    @(posedge clk_out);
    clk_out_next_position = $realtime;
  endtask:compare_freq
endclass : pll_cfg_test
**Post date:** [December 9, 2019, 5:36pm UTC](https://verificationacademy.com/forums/t/unable-to-pass-interface-signal-by-reference-to-a-task/36899/2 "2019-12-09T17:36:37Z")
</div>
_In reply to [umeshr1](https://verificationacademy.com/forums/t/unable-to-pass-interface-signal-by-reference-to-a-task/36899):_
Works for me. Just a few extra lines would have made a complete runnable example
```verilog
   logic cpu_pll_clk_out = 0;
   always #2 cpu_pll_clk_out++;
endinterface
import uvm_pkg::*;
`include "uvm_macros.svh"
  endfunction : new
    join_none
    #20us;
    real clk_freq;
    @(posedge clk_out);
    repeat(10)
    @(posedge clk_out);
     $display("done");
   test_probe_intf intf();
      uvm_config_db #(virtual test_probe_intf)::set(null, "*","test_probe_if", intf);
      run_test("pll_cfg_test");
**Post date:** [December 11, 2019, 5:34am UTC](https://verificationacademy.com/forums/t/unable-to-pass-interface-signal-by-reference-to-a-task/36899/3 "2019-12-11T05:34:06Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/unable-to-pass-interface-signal-by-reference-to-a-task/36899/2):_
I could not see the “done” message being displayed, the test just completes without this. I guess it is a simulator issue then. I will contact the tool owner.
