# To restrict the visibility of interface to agent only using config\_db
**URL:** <https://verificationacademy.com/forums/t/to-restrict-the-visibility-of-interface-to-agent-only-using-config-db/38044>\
**Tags:** UVM, uvm-config\_db\
**Created:** [September 8, 2020, 3:47pm UTC](https://verificationacademy.com/forums/t/to-restrict-the-visibility-of-interface-to-agent-only-using-config-db/38044 "2020-09-08T15:47:14Z")\
**Showing post:** 2
**Post date:** [September 8, 2020, 4:37pm UTC](https://verificationacademy.com/forums/t/to-restrict-the-visibility-of-interface-to-agent-only-using-config-db/38044/2 "2020-09-08T16:37:39Z")
_In reply to [jj\_bukhari](https://verificationacademy.com/forums/t/to-restrict-the-visibility-of-interface-to-agent-only-using-config-db/38044):_
Your problem is in the config\_db set command:
```verilog
uvm_config_db#(virtual intf)::set(null,"*.agent_h","intf_h",intf_h);
Your code restricts the virtual interface to a component which has at the end of its hierarchical path ‘agent\_h’.
Replacing the 2nd argument with awildcard ‘\*’ will work.
_[View the full topic](https://verificationacademy.com/forums/t/to-restrict-the-visibility-of-interface-to-agent-only-using-config-db/38044)._
