# SystemVerilog generate statement scope
**URL:** <https://verificationacademy.com/forums/t/systemverilog-generate-statement-scope/40421>\
**Category:** SystemVerilog\
**Tags:** systemverilog-generate, SystemVerilog\
**Created:** [May 19, 2022, 2:20am UTC](https://verificationacademy.com/forums/t/systemverilog-generate-statement-scope/40421 "2022-05-19T02:20:17Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![arquer](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/a/e95f7d/32.png) [@arquer](https://verificationacademy.com/forums/u/arquer)\
**Post date:** [May 19, 2022, 2:20am UTC](https://verificationacademy.com/forums/t/systemverilog-generate-statement-scope/40421/1 "2022-05-19T02:20:17Z")
</div>
up until a minute ago I thought I understood the generate construct of SystemVerilog. I have used it plenty of times in the past with success.
However, looking through some code from Xilinx I found this:
```verilog
module xpm_fifo_rst # (
  parameter integer COMMON_CLOCK = 1,
  parameter integer CDC_DEST_SYNC_FF = 2,
  parameter integer SIM_ASSERT_CHK = 0
  input wire rst,
  input wire wr_clk,
  input wire rd_clk,
  output wire wr_rst,
  output wire rd_rst,
  output wire wr_rst_busy,
  output wire rd_rst_busy
  reg [1:0] power_on_rst = 2'h3;
  wire rst_i;
  // Reset Logic
  //Keeping the power on reset to work even when the input reset(to xpm_fifo) is not applied or not using
   always @ (posedge wr_clk) begin
     power_on_rst <= {power_on_rst[0], 1'b0};
   assign rst_i = power_on_rst[1] | rst;
  // Write and read reset generation for common clock FIFO
   if (COMMON_CLOCK == 1) begin : gen_rst_cc
    reg [2:0] fifo_wr_rst_cc = 3'b00;
    assign wr_rst = fifo_wr_rst_cc[2];
    assign rd_rst = fifo_wr_rst_cc[2];
    assign rd_rst_busy = fifo_wr_rst_cc[2];
    assign wr_rst_busy = fifo_wr_rst_cc[2];
  // synthesis translate_off
    `ifndef DISABLE_XPM_ASSERTIONS
    if (SIM_ASSERT_CHK == 1) begin: assert_rst
        assert (!$isunknown(rst)) else $warning ("Input port 'rst' has unknown value 'X' or 'Z' at %0t. This may cause the outputs of FIFO to be 'X' or 'Z' in simulation. Ensure 'rst' has a valid value ('0' or '1')",$time);
    end : assert_rst
  `endif
  // synthesis translate_on
      if (rst_i) begin
        fifo_wr_rst_cc <= 3'h7;
      end else begin
  	fifo_wr_rst_cc <= {fifo_wr_rst_cc[1:0],1'b0};
  end : gen_rst_cc
  // Write and read reset generation for independent clock FIFO
  if (COMMON_CLOCK == 0) begin : gen_rst_ic
    wire fifo_wr_rst_rd;
    wire fifo_rd_rst_wr_i;
    reg fifo_wr_rst_i = 1'b0;
    reg wr_rst_busy_i = 1'b0;
    reg fifo_rd_rst_i = 1'b0;
    reg fifo_rd_rst_ic = 1'b0;
    reg fifo_wr_rst_ic = 1'b0;
    reg wr_rst_busy_ic = 1'b0;
    reg rst_seq_reentered = 1'b0;
    assign wr_rst = fifo_wr_rst_ic | wr_rst_busy_ic;
    assign rd_rst = fifo_rd_rst_ic;
    assign rd_rst_busy = fifo_rd_rst_ic;
    assign wr_rst_busy = wr_rst_busy_ic;
    (* fsm_safe_state = "default_state" *) enum logic [2:0] {WRST_IDLE = 3'b000,
                      WRST_IN = 3'b010,
                      WRST_OUT = 3'b111,
                      WRST_EXIT = 3'b110,
                      WRST_GO2IDLE = 3'b100} curr_wrst_state = WRST_IDLE, next_wrst_state = WRST_IDLE;
    (* fsm_safe_state = "default_state" *) enum logic [1:0] {RRST_IDLE = 2'b00,
                      RRST_IN = 2'b10,
                      RRST_OUT = 2'b11,
                      RRST_EXIT = 2'b01} curr_rrst_state = RRST_IDLE, next_rrst_state = RRST_IDLE;
   end : assert_rst
  `endif
     if (rst_i) begin
       rst_seq_reentered <= 1'b0;
     end else begin
       if (curr_wrst_state == WRST_GO2IDLE) begin
	 rst_seq_reentered <= 1'b1;
   always @* begin
      case (curr_wrst_state)
         WRST_IDLE: begin
            if (rst_i)
               next_wrst_state <= WRST_IN;
               next_wrst_state <= WRST_IDLE;
         WRST_IN: begin
            if (rst_i)
            else if (fifo_rd_rst_wr_i)
               next_wrst_state <= WRST_OUT;
         WRST_OUT: begin
            if (rst_i)
            else if (~fifo_rd_rst_wr_i)
               next_wrst_state <= WRST_EXIT;
         WRST_EXIT: begin
            if (rst_i)
            else if (~rst & ~rst_seq_reentered)
               next_wrst_state <= WRST_GO2IDLE;
            else if (rst_seq_reentered)
         WRST_GO2IDLE: begin
         default: next_wrst_state <= WRST_IDLE;
      endcase
     curr_wrst_state <= next_wrst_state;
     fifo_wr_rst_ic <= fifo_wr_rst_i;
     wr_rst_busy_ic <= wr_rst_busy_i;
   always @* begin
         WRST_IDLE : fifo_wr_rst_i = rst_i;
         WRST_IN : fifo_wr_rst_i = 1'b1;
         WRST_OUT : fifo_wr_rst_i = 1'b0;
         WRST_EXIT : fifo_wr_rst_i = 1'b0;
         WRST_GO2IDLE : fifo_wr_rst_i = 1'b1;
         default: fifo_wr_rst_i = fifo_wr_rst_ic;
      endcase
   always @* begin
         WRST_IDLE: wr_rst_busy_i = rst_i;
         WRST_IN : wr_rst_busy_i = 1'b1;
         WRST_OUT : wr_rst_busy_i = 1'b1;
         WRST_EXIT: wr_rst_busy_i = 1'b1;
         default: wr_rst_busy_i = wr_rst_busy_ic;
      endcase
    always @* begin
      case (curr_rrst_state)
         RRST_IDLE: begin
            if (fifo_wr_rst_rd)
               next_rrst_state <= RRST_IN;
               next_rrst_state <= RRST_IDLE;
         RRST_IN : next_rrst_state <= RRST_OUT;
         RRST_OUT : begin
            if (~fifo_wr_rst_rd)
               next_rrst_state <= RRST_EXIT;
         RRST_EXIT: next_rrst_state <= RRST_IDLE;
         default: next_rrst_state <= RRST_IDLE;
      endcase
   always @ (posedge rd_clk) begin
     curr_rrst_state <= next_rrst_state;
     fifo_rd_rst_ic <= fifo_rd_rst_i;
   always @* begin
         RRST_IDLE: fifo_rd_rst_i <= fifo_wr_rst_rd;
         RRST_IN : fifo_rd_rst_i <= 1'b1;
         RRST_OUT : fifo_rd_rst_i <= 1'b1;
         RRST_EXIT: fifo_rd_rst_i <= 1'b0;
         default: fifo_rd_rst_i <= 1'b0;
      endcase
    // Synchronize the wr_rst (fifo_wr_rst_ic) in read clock domain
    xpm_cdc_sync_rst #(
      .DEST_SYNC_FF (CDC_DEST_SYNC_FF),
      .INIT (0),
      .INIT_SYNC_FF (1),
      .SIM_ASSERT_CHK (0),
      .VERSION (0))
      wrst_rd_inst (
        .src_rst (fifo_wr_rst_ic),
        .dest_clk (rd_clk),
        .dest_rst (fifo_wr_rst_rd));
    // Synchronize the rd_rst (fifo_rd_rst_ic) in write clock domain
    xpm_cdc_sync_rst #(
      .INIT (0),
      .INIT_SYNC_FF (1),
      .VERSION (0))
      rrst_wr_inst (
        .src_rst (fifo_rd_rst_ic),
        .dest_clk (wr_clk),
        .dest_rst (fifo_rd_rst_wr_i));
  end : gen_rst_ic
endmodule : xpm_fifo_rst
This is just a module that comes with the current Vivado installation and which is used to handle reset signals in a fifo, I pasted the entire thing in case it is relevant.
Just a few lines into the module there a line which reads
```verilog
that if statement is not inside of any always, function or task, it is just standing on it’s own. Inside the if code there are register definitions, assign statements, etc.
My confusion comes from the fact that I always thought that in order to have conditional instantiations, declarations and assignments one always needed a generate block.
Can somebody clarify that for me please? I have searched everywhere and I have not found any examples of code where the generate or if statements are used as the case above…
**Post date:** [May 19, 2022, 5:29am UTC](https://verificationacademy.com/forums/t/systemverilog-generate-statement-scope/40421/2 "2022-05-19T05:29:19Z")
</div>
_In reply to [arquer](https://verificationacademy.com/forums/t/systemverilog-generate-statement-scope/40421):_
The generate/endgenerate keywords were made optional in Verilog IEEE Std 1364-2005. The compiler can tell from the context whether **for** , **if** , and **case** statements are procedural or represent a generate block.
What’s really _ **amusing** _/_ **annoying** _ are the assertions that follow the code you posted wrapped in three layers of guards: 1) a pragma comment, 2) a conditional compiler directive, and 3) a generate-if
```verilog
    end : assert_rst
  `endif
I don’t understand why people use pragma synthesis on/off comments when conditional compiler directives are so much easier for tools to work with (comments get stripped away by many pre-processors. Even easier is to write the assertion by itself and there are control constructs to turn on/off assertions without needed any guards.
```verilog
assert property (@(posedge clk) !$isunknown(rst)) else $warning ("Input port 'rst' has unknown value 'X' or 'Z' at %0t. This may cause the outputs of FIFO to be 'X' or 'Z' in simulation. Ensure 'rst' has a valid value ('0' or '1')",$time);
**Post date:** [May 19, 2022, 5:23pm UTC](https://verificationacademy.com/forums/t/systemverilog-generate-statement-scope/40421/3 "2022-05-19T17:23:34Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/systemverilog-generate-statement-scope/40421/2):_
Thanks Dave! that makes a lot of sense! :)
