# System veilog Regular expressions
**URL:** <https://verificationacademy.com/forums/t/system-veilog-regular-expressions/33277>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, regular-expressions\
**Created:** [July 6, 2017, 12:14pm UTC](https://verificationacademy.com/forums/t/system-veilog-regular-expressions/33277 "2017-07-06T12:14:07Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![saritr](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/df705f/32.png) [@saritr](https://verificationacademy.com/forums/u/saritr)\
**Post date:** [July 6, 2017, 12:14pm UTC](https://verificationacademy.com/forums/t/system-veilog-regular-expressions/33277/1 "2017-07-06T12:14:07Z")
</div>
I understood that System verilog does not have very good regular expression support inbuilt.
How can I check in systemVerilog that a srting matches to the following regular expressions: “\d+(ns|ps|us)”
**Post date:** [July 6, 2017, 3:11pm UTC](https://verificationacademy.com/forums/t/system-veilog-regular-expressions/33277/2 "2017-07-06T15:11:00Z")
</div>
_In reply to [saritr](https://verificationacademy.com/forums/t/system-veilog-regular-expressions/33277):_
You have a number of different options.
Some simulators already support a set of SystemVerilog string method extensions that handle regular expressions such as str.match() and str.search().
```verilog
result = str.match(“pattern”); // returns true if the pattern is matched with the str.
If you are using the UVM, there is a DPI routine that does the same thing
```verilog
result = uvm_pkg::uvm_re_match(“pattern”,str);
There are number of other packages out there such as SVunit that also provide the DPI routines for you.
