# SVA to check clock toggling for a fixed number of cycles
**URL:** <https://verificationacademy.com/forums/t/sva-to-check-clock-toggling-for-a-fixed-number-of-cycles/38630>\
**Category:** SystemVerilog\
**Tags:** SVA, Assertion-Multiple-clocks, SystemVerilog, assertion, clock\
**Created:** [January 22, 2021, 7:29pm UTC](https://verificationacademy.com/forums/t/sva-to-check-clock-toggling-for-a-fixed-number-of-cycles/38630 "2021-01-22T19:29:59Z")\
**Showing post:** 4
**Author:** ![nimitz\_class](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/n/e9c0ed/32.png) [@nimitz\_class](https://verificationacademy.com/forums/u/nimitz_class)\
**Post date:** [January 22, 2021, 10:27pm UTC](https://verificationacademy.com/forums/t/sva-to-check-clock-toggling-for-a-fixed-number-of-cycles/38630/4 "2021-01-22T22:27:00Z")
_In reply to [ben@SystemVerilog.us](https://verificationacademy.com/forums/t/sva-to-check-clock-toggling-for-a-fixed-number-of-cycles/38630/3):_
> _In reply to [foxtrot](https://verificationacademy.com/forums/t/sva-to-check-clock-toggling-for-a-fixed-number-of-cycles/38630/3):_
```verilog
// sclk to be stable and toggling for 4 clock cycles
// Q: What is the definition of "stable"?
// steady in value for 4 ref_clk cycles or
// toggling for 4 sck cycles? You mention both
// before ack goes high and stable and toggling 8 clock cycles after ack goes low.
// ack goes high after req is asserted, so that's the 4 clock cycles delay for ack before it's asserted.
// Q: Very poor defintion of the requirements.
// Now you are talking about sclk to be a clock used as delay.
// GIGO. I don't understand your requirements.
property sclk_ack_req;
@(posedge ref_clk) $rose(req) |-> sclk[*4] ##1 $rose(ack) ##3 $fell(ack) ##1 sclk[*8];
// Above property says:
// At the rose(req) you have sclk==1 for 4 consecutive ref_clk clock cyccles.
// This is then followed by a rose(ack)and 3 ref_clk later ack fell.
// This is then followed by sclk==1 for 8 consecutive ref_clk clock cyccles.
// Note that $rose(ack) ##3 $fell(ack) does not cover the case of this sequence
// $rose(ack) ##1 ack==0 ##1 ack==1 ##1 ack==0
// 0 1 x 1 0
// to avoid this, you need
// $rose(ack) ##0 ack[*3] ##1 $fell(ack)
For training, consulting, services: contact [http://cvcblr.com/home.html](http://cvcblr.com/home.html)
\*\* SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
1. SVA Package: Dynamic and range delays and repeats [SVA: Package for dynamic and range delays and repeats - SystemVerilog - Verification Academy](https://rb.gy/a89jlh)
2. Free books: Component Design by Example [https://rb.gy/9tcbhl](https://rb.gy/9tcbhl)
Real Chip Design and Verification Using Verilog and VHDL($3) [https://rb.gy/cwy7nb](https://rb.gy/cwy7nb)
3. Papers:
[https://verificationacademy.com/verification-horizons/july-2020-volume-16-issue-2](https://verificationacademy.com/verification-horizons/july-2020-volume-16-issue-2)
[https://verificationacademy.com/news/verification-horizons-march-2018-issue](https://verificationacademy.com/news/verification-horizons-march-2018-issue)
[https://verificationacademy.com/verification-horizons/february-2013-volume-9-issue-1/SVA-in-a-UVM-Class-based-Environment](https://verificationacademy.com/verification-horizons/february-2013-volume-9-issue-1/SVA-in-a-UVM-Class-based-Environment)
Let’s consider your comment, I don’t want to check for sclk==1 for 4 clock cycles, but I want to check whether it’s toggling for 4 clock cycles. I’m unable to do that toggling part, this is where I need your help.
_[View the full topic](https://verificationacademy.com/forums/t/sva-to-check-clock-toggling-for-a-fixed-number-of-cycles/38630)._
