# SVA: Sampling clk on consequent
**URL:** <https://verificationacademy.com/forums/t/sva-sampling-clk-on-consequent/29945>\
**Category:** SystemVerilog\
**Tags:** SVA-Assertion, SystemVerilog\
**Created:** [September 15, 2014, 3:10pm UTC](https://verificationacademy.com/forums/t/sva-sampling-clk-on-consequent/29945 "2014-09-15T15:10:56Z")\
**Showing post:** 2
**Post date:** [September 15, 2014, 9:03pm UTC](https://verificationacademy.com/forums/t/sva-sampling-clk-on-consequent/29945/2 "2014-09-15T21:03:52Z")
> @(posedge clk1) $fell(A) |-\> ($rose(clk1)==1) [\*2];
The “($rose(clk1)” clocked with @(posedge clk1 means that @(posedge clk1) you are sampling the signal clk1 one delta time (i.e., just before) the posedge clk1. At that time, the sampling of clk1 has a value of ZERO!!! Also, you are using |-\> (i.e., in the same cycle), thus the assertion will fail at $fell(A).
You could however do the following:
```auto
ap_2cloks: assert property(@(posedge clk1) $fell(A) |=> strong(1[*2]);
The strong is necessary to qualify an assertion as a failure if the consequent never terminates at the end of simulation.
_[View the full topic](https://verificationacademy.com/forums/t/sva-sampling-clk-on-consequent/29945)._
