# SVA Repetition operator \[=
**URL:** <https://verificationacademy.com/forums/t/sva-repetition-operator/30391>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog\
**Created:** [February 23, 2015, 4:16pm UTC](https://verificationacademy.com/forums/t/sva-repetition-operator/30391 "2015-02-23T16:16:41Z")\
**Posts on this page:** 8\
**Page:** 1
<div class="post-metadata">
**Author:** ![Jartar](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/j/ccd318/32.png) [@Jartar](https://verificationacademy.com/forums/u/Jartar)\
**Post date:** [February 23, 2015, 4:16pm UTC](https://verificationacademy.com/forums/t/sva-repetition-operator/30391/1 "2015-02-23T16:16:41Z")
</div>
I am trying to implement this check: between two consecutive asserts of signal A separated by any no of clock cycles signal B should be asserted only once. i.e. A cannot be asserted without B received for previous A.
I tried to use the repetition operator for this [=
Sequence:
A |-\> (B[=1]) ## [1:$] A;
I’ve tried to introduce a bug and get this assertion to fire. But not sure if this will work.
any thoughts ?
**Author:** ![user49](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/user49/32/1084_2.png) [@user49](https://verificationacademy.com/forums/u/user49)\
**Post date:** [February 24, 2015, 4:25pm UTC](https://verificationacademy.com/forums/t/sva-repetition-operator/30391/2 "2015-02-24T16:25:13Z")
</div>
In property (A |-\> (B[=1]) ## [1:] A) you need to understand the equivalents for the [=m] and [-\>m] b[=m] is equivalent to ( b [-\>m] ##1 !b [\*0:] )
b[-\>m] is equivalent to ( !b [\*0:] ##1 b)[\*m] Thus, what you wrote is equivalent to (A |-\> B [-\>1] ##1 !B [\*0:] ## [1:$] A)
and the following thread would pass the property, something you may not want
(A |-\> B [-\>1] ##1 A) // because (!b[\*0] ##1 A) is same as (A)
Also, because of the implication operator, this sequence would succeed:
A ##0 B ##1 A // Not what you want.
I suggest you change it to:
```auto
$rose(A) |=> (B[=1]) ##1 A // same as $rose(A) |=> B[->1] ##1 !B[*0:$]##1 A
// This would be satisfied by any of the following sequences
  A ##1 B ##1 A or
  A ##1 !B ##1B ##1 !B ##1A
// --- If you want a !B separation between B and A, then this would work
 $rose(A) |=> (B[->1]) ##1 !B[*1:$] ##1 A
  A ##1 B ##1 !B ##1 A or
[http://www.systemverilog.us/](http://www.systemverilog.us/) [ben@systemverilog.us](mailto:ben@systemverilog.us)
- SystemVerilog Assertions Handbook 3rd Edition, 2013 ISBN 878-0-9705394-3-6
- A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
- Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
- Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 0-9705394-2-8
- Component Design by Example ", 2001 ISBN 0-9705394-0-1
- VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
- VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
**Post date:** [February 25, 2015, 7:25pm UTC](https://verificationacademy.com/forums/t/sva-repetition-operator/30391/3 "2015-02-25T19:25:54Z")
</div>
_In reply to [ben@SystemVerilog.us](https://verificationacademy.com/forums/t/sva-repetition-operator/30391/2):_
Thanks very much. will try it out.
**Author:** ![lilyding](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/l/919ad9/32.png) [@lilyding](https://verificationacademy.com/forums/u/lilyding)\
**Post date:** [February 27, 2015, 5:09am UTC](https://verificationacademy.com/forums/t/sva-repetition-operator/30391/4 "2015-02-27T05:09:19Z")
</div>
_In reply to [Jartar](https://verificationacademy.com/forums/t/sva-repetition-operator/30391/3):_
Hi Ben/Jartar,
I have something similar to your case. In the following code, I intend to implement there is only one outstanding request, i.e. After A&&B , it has to wait response C && D asserted, and the next A&&B has to be presented after C && D have already de-asserted, but the cycles in-between could be any number of cycle, does the following implementation make sense? Thanks.
sequence request;
##[1:$] A && B;
endsequence
sequence response;
##[1:] C && D ##[1:] !C[\*1:] ##[1:] A && B ;
endsequence
property outstanding\_req;
@(posedge clk) request |-\> response;
assert property (outstanding\_req);
**Post date:** [February 27, 2015, 6:01am UTC](https://verificationacademy.com/forums/t/sva-repetition-operator/30391/5 "2015-02-27T06:01:29Z")
</div>
_In reply to [ben@SystemVerilog.us](https://verificationacademy.com/forums/t/sva-repetition-operator/30391/4):_
Thanks Ben for the correction. The operand after intersect is to make sure there is no A&&B occurring at the same time, right?
This is actually a checker on an AXI read interface, A&B is like ARREADY \* ARVALID, C&D is like RREADY & RVALID. So from protocol wise, would this assertion also make sense? Thanks much for your insight!
**Post date:** [February 27, 2015, 6:16am UTC](https://verificationacademy.com/forums/t/sva-repetition-operator/30391/6 "2015-02-27T06:16:58Z")
</div>
_In reply to [nickbayshore](https://verificationacademy.com/forums/t/sva-repetition-operator/30391/5):_
Also, what’s that label ap\_abcdab for? I didn’t see a label from this assertion tutorial website:
[http://www.doulos.com/knowhow/sysverilog/tutorial/assertions/](http://www.doulos.com/knowhow/sysverilog/tutorial/assertions/)
**Post date:** [February 27, 2015, 6:33am UTC](https://verificationacademy.com/forums/t/sva-repetition-operator/30391/7 "2015-02-27T06:33:04Z")
</div>
_In reply to [nickbayshore](https://verificationacademy.com/forums/t/sva-repetition-operator/30391/6):_
[Ben] Correct
[Ben] Makes sense; keep in mind that I am not familiar with that protocol. In any case, an assertion reflects the requirements, and they should express the intent (what is desired) and they should be accurate; thus, they should includes assumptions tha may be in your head. In this case you have something like: X … Y … X. What happens between X and Y?
BTW, I made a mistake in the request and response Code should be:
```auto
sequence request;
   A && B; // DOn't need the ##[1:$] <------
   // Do you need a $rose?
endsequence
sequence response;
     ( (##[1:$] C && D ##[1:$] !(C && D)[*1:$]) intersect
       (1 ##1 !(A && B)[*1:$]) ) // <-- added the 1 ##1 because both sequences start at same time as the antecedent
      ##[1:$] A && B ;
endsequence
ap_abcdab: assert property(@(posedge clk)
                     request |-> response);
sequence response2; // Another option
     ( (##[0:$] C && D ##[1:$] !(C && D)[*1:$]) intersect // <<-- ##[0:$ insteas of ##[1:$
       (!(A && B)[*1:$]) )
      ##[1:$] A && B ;
endsequence
ap_abcdab2: assert property(@(posedge clk)
                     request |=> response2); // |=> instead of |->
[Ben] I strongly recommend that every assertion statement have a label; it makes debugging far easier. Otherwise, the tool will generate a funky, nonsense label for you.
**Post date:** [February 27, 2015, 6:36am UTC](https://verificationacademy.com/forums/t/sva-repetition-operator/30391/8 "2015-02-27T06:36:13Z")
</div>
_In reply to [nickbayshore](https://verificationacademy.com/forums/t/sva-repetition-operator/30391/7):_
// [Ben] How do you detect that A&&B does not occur while you wait for C&&D?
```auto
sequence request;
  // ##[1:$] A && B; // Update: change to
  A && B; // may need a $rose, check requirements
endsequence
sequence response;
       // (!(A && B)[*1:$]) ) // need a ##1
       (1 ##1 !(A && B)[*1:$]) ) // Updated
      ##[1:$] A && B ;
endsequence
Ben [SystemVerilog.us](http://SystemVerilog.us)
