# SVA evaluation
**URL:** <https://verificationacademy.com/forums/t/sva-evaluation/33470>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog\
**Created:** [September 9, 2017, 10:36am UTC](https://verificationacademy.com/forums/t/sva-evaluation/33470 "2017-09-09T10:36:01Z")\
**Showing post:** 2
**Author:** ![user49](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/user49/32/1084_2.png) [@user49](https://verificationacademy.com/forums/u/user49)\
**Post date:** [September 10, 2017, 7:14pm UTC](https://verificationacademy.com/forums/t/sva-evaluation/33470/2 "2017-09-10T19:14:10Z")
_In reply to [Harshit](https://verificationacademy.com/forums/t/sva-evaluation/33470):_
> Why SystemVerilog assertions are evaluated in observed region, although the values are sampled in preponed region ?
Keep in mind that SystemVerilog must emulate concurrency using a sequencial non-concurret processing computer. Before getting into an example that explains the regions, let me review the regions, as explained from my [SVA Handbook 4th Edition](http://goo.gl/JOfuEB)
The bottom line:
1. In an assertion, all signals are sampled in the Preponed region
Thus, with (1, y=q), the module variable “q” is sampled,
and every “q” referenced is the sampled value
2. If within the sequence-matched-item, I update my property local variable with the return of a function call, like (1, w=getq()), that call is made in the Observed region, past the Active and NBA regions. Thus, in this model (below) w gets the updated value of q.
390 sampled q= 25, current q= 25, past q= 8, var w= 31
Go over the example and think about the results. It all makes sense.
 ![](https://verificationacademy.com/forums/uploads/default/original/1X/29336b539514a1c55a258551712b19acaf25b283.png)
Example code: [http://SystemVerilog.us/fv/regions2.sv](http://SystemVerilog.us/fv/regions2.sv)
```verilog
module top;
	bit clk, a;
	int q, qin, k;
	always_comb k=q+1'b1;
		initial forever #10 clk=!clk;
	always_ff @(posedge clk) begin
		q <= qin;
	function automatic int getq();
		automatic int v;
		v=k;
		return v;
	endfunction : getq
	property test;
		int y, w;
		a |->
			(1, y=q, $display("%t sampled q=%d, current q=%d, past q=%d, var y=%d", $time, $sampled(q), q, $past(q), y)) ##0
			(1, w=getq(), $display("%t sampled q=%d, current q=%d, past q=%d, var w=%d", $time, $sampled(q), q, $past(q), w));
	ap_test: assert property(test);
		repeat(200) begin
			@(posedge clk); #3;
			if (!randomize(a, qin) with
					{ a dist {1'b1:=1, 1'b0:=3};
					  qin dist {[1:10]:=1, [20:30]:=2};
					$stop;
Sim results
 ![](https://verificationacademy.com/forums/uploads/default/original/1X/6ecae83f06207a9a7f3132c909cee2ebc6eb3208.png)
For training, consulting, services: contact [Home - My cvcblr](http://cvcblr.com/home)
- [SVA Handbook 4th Edition, 2016 ISBN 978-1518681448](http://goo.gl/JOfuEB)
- [Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 978-1539769712](https://goo.gl/d10QHh)
_[View the full topic](https://verificationacademy.com/forums/t/sva-evaluation/33470)._
