# SV assertion for clock gating & Reset check
**URL:** <https://verificationacademy.com/forums/t/sv-assertion-for-clock-gating-reset-check/32495>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog\
**Created:** [November 6, 2016, 11:42am UTC](https://verificationacademy.com/forums/t/sv-assertion-for-clock-gating-reset-check/32495 "2016-11-06T11:42:07Z")\
**Showing post:** 5
**Author:** ![S.P.Rajkumar.V](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/e9a140/32.png) [@S.P.Rajkumar.V](https://verificationacademy.com/forums/u/S.P.Rajkumar.V)\
**Post date:** [November 12, 2016, 12:23pm UTC](https://verificationacademy.com/forums/t/sv-assertion-for-clock-gating-reset-check/32495/5 "2016-11-12T12:23:48Z")
_In reply to [ben@SystemVerilog.us](https://verificationacademy.com/forums/t/sv-assertion-for-clock-gating-reset-check/32495/4):_
Hi Ben,
Thank you. ‘within’ has perfectly worked in this scenario.
In the test scenario the above sequence has satisfied once and assertion has passed; and then the second time the test scenario stopped at reset release itself, there-by encountering an **incomplete assertion issue** at the end of simulation. The same issue can occur with all other previous assertions as well (since it all depends on stimulus).
I hope the only solution here is to re-code each assertion sequence above by splitting them into multiple parts (say for ex. one each for reset-assertion, de-assertion, and intermediate checks).
Could you just comment, if there is any other way to go-ahead with the existing code?
Regards,
Rajkumar.
_[View the full topic](https://verificationacademy.com/forums/t/sv-assertion-for-clock-gating-reset-check/32495)._
