# Stop and restart assertion from sequence
**URL:** <https://verificationacademy.com/forums/t/stop-and-restart-assertion-from-sequence/36061>\
**Category:** UVM\
**Tags:** UVM, sequence, assertoff, asserton\
**Created:** [May 7, 2019, 7:27am UTC](https://verificationacademy.com/forums/t/stop-and-restart-assertion-from-sequence/36061 "2019-05-07T07:27:34Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![jerin1](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/j/6de8d8/32.png) [@jerin1](https://verificationacademy.com/forums/u/jerin1)\
**Post date:** [May 7, 2019, 7:27am UTC](https://verificationacademy.com/forums/t/stop-and-restart-assertion-from-sequence/36061/1 "2019-05-07T07:27:34Z")
</div>
Is there a way to stop and restarts assertions from the uvm sequence.
I have a testbench requirement where in the middle of a sequence there is a dirty period,where the assertions are expected to fail. I want to disable
all the assertions (under testbench heirarchy) during this dirty period and enable it again after this dirty period is over.
I tried adding following in my sequence, but it gave error
$assertoff(1,uvm\_test\_top.testbench);
$assertoff(1,testbench);
\*The name (‘uvm\_test\_top.testbench’) was not found in the current scope. Please verify the spelling of the name ‘uvm\_test\_top.testbench’
\*\* Error (suppressible): …/…/…/…/verification/testcases/sequences/axi\_rgm\_seq\_lib\_hdmi\_2\_1\_b2b.sv(8943): (vlog-7027) The name (‘testbench’) was not found in the current scope. Please verify the spelling of the name ‘testbench’.\*
Could you please advice on what should be my approach for this requirement.
Thanks in Advance.
**Post date:** [May 7, 2019, 1:50pm UTC](https://verificationacademy.com/forums/t/stop-and-restart-assertion-from-sequence/36061/2 "2019-05-07T13:50:16Z")
</div>
_In reply to [jerin](https://verificationacademy.com/forums/t/stop-and-restart-assertion-from-sequence/36061):_
Assertions are always signal- related. Defining a property/assertion allows you to switch-off thhe evaluation for certain periods using a corresponding signal.
The construct is
```verilog
disable iff(your_signal).
As far as the value of your signal is high the evalution of your property is suppressed.
A reasobale solution would be to generate ‘your\_signal’ in your driver, depending on a special indication in your seq\_item.
**Post date:** [May 8, 2019, 1:58am UTC](https://verificationacademy.com/forums/t/stop-and-restart-assertion-from-sequence/36061/3 "2019-05-08T01:58:25Z")
</div>
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/stop-and-restart-assertion-from-sequence/36061/2):_
Thanks chr\_sue.
I will try it out.
