# Static function vs function static
**URL:** <https://verificationacademy.com/forums/t/static-function-vs-function-static/38152>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog\
**Created:** [October 1, 2020, 3:03pm UTC](https://verificationacademy.com/forums/t/static-function-vs-function-static/38152 "2020-10-01T15:03:35Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![OmGaneshBK](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/o/90ced4/32.png) [@OmGaneshBK](https://verificationacademy.com/forums/u/OmGaneshBK)\
**Post date:** [October 1, 2020, 3:03pm UTC](https://verificationacademy.com/forums/t/static-function-vs-function-static/38152/1 "2020-10-01T15:03:35Z")
</div>
1.My question is Module inside all the function are static in nature but how the output is behaving like an automatic .Any one can help me
```verilog
module tryfact;
  // define the function
  function integer factorial (input [31:0] operand);
    if (operand >= 2)
    factorial = factorial (operand - 1) * operand;
    factorial = 1;
  endfunction: factorial
  // test the function
  integer result;
    for (int n = 0; n <= 7; n++) begin
      result = factorial(n);
      $display("%0d factorial=%0d", n, result);
endmodule: tryfact
Output :
```auto
0 factorial=1
1 factorial=1
2 factorial=1
3 factorial=1
4 factorial=1
5 factorial=1
6 factorial=1
7 factorial=1
**Post date:** [October 1, 2020, 4:19pm UTC](https://verificationacademy.com/forums/t/static-function-vs-function-static/38152/2 "2020-10-01T16:19:38Z")
</div>
_In reply to [Om Ganesh B k](https://verificationacademy.com/forums/t/static-function-vs-function-static/38152):_
Please use
````tags
(https://verificationacademy.com/forums/announcements/please-format-your-code-code-and/code-tags) making your code easier to read. I have added them for you.
Your output is not the same as if you had declared the function as automatic
``` verilog
function automatic integer factorial (input [31:0] operand);
I get
[code]# run -all
# 0 factorial=1
# 1 factorial=1
# 2 factorial=2
# 3 factorial=6
# 4 factorial=24
# 5 factorial=120
# 6 factorial=720
# 7 factorial=5040
```auto
