# Start sequence on sequencer using config\_db in test class?
**URL:** <https://verificationacademy.com/forums/t/start-sequence-on-sequencer-using-config-db-in-test-class/39428>\
**Tags:** UVM, uvm-config\_db\
**Created:** [August 12, 2021, 12:22pm UTC](https://verificationacademy.com/forums/t/start-sequence-on-sequencer-using-config-db-in-test-class/39428 "2021-08-12T12:22:26Z")\
**Showing post:** 4
**Post date:** [August 13, 2021, 7:38am UTC](https://verificationacademy.com/forums/t/start-sequence-on-sequencer-using-config-db-in-test-class/39428/4 "2021-08-13T07:38:34Z")
_In reply to [Harshad](https://verificationacademy.com/forums/t/start-sequence-on-sequencer-using-config-db-in-test-class/39428/3):_
There are 2 ways to start a sequence:
(1) starting a sequence automatically by using the consept of the ‘default sequence’. The default sequence will be set using the config\_db.
(2) starting a sequence manually by using the start method of the sequencer.
Method (2) is the recommended way to start a sequence. Method (1) is a relict of the OVM.
_[View the full topic](https://verificationacademy.com/forums/t/start-sequence-on-sequencer-using-config-db-in-test-class/39428)._
