# Simulation changing with respect to Sequence name
**URL:** <https://verificationacademy.com/forums/t/simulation-changing-with-respect-to-sequence-name/39476>\
**Tags:** UVM, sequence, create\
**Created:** [August 25, 2021, 9:52am UTC](https://verificationacademy.com/forums/t/simulation-changing-with-respect-to-sequence-name/39476 "2021-08-25T09:52:13Z")\
**Showing post:** 2
**Author:** ![harsh\_pandya](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/harsh_pandya/32/2973_2.png) [@harsh\_pandya](https://verificationacademy.com/forums/u/harsh_pandya)\
**Post date:** [August 25, 2021, 4:28pm UTC](https://verificationacademy.com/forums/t/simulation-changing-with-respect-to-sequence-name/39476/2 "2021-08-25T16:28:48Z")
_In reply to [bachan21](https://verificationacademy.com/forums/t/simulation-changing-with-respect-to-sequence-name/39476):_
I have corrected some Syntex error from your code and tried below code it’s working fine for me with “SEQ” or “simple\_sequence”.
So, there is not issue of name “SEQ” or “simple\_sequence”.
name is only just use to create object only.
```verilog
// Code your testbench here
// or browse Examples
`include "uvm_macros.svh"
import uvm_pkg::*;
class simple_sequence extends uvm_sequence;
  `uvm_object_utils(simple_sequence)
  function new(string name="");
    super.new(name);
  endfunction : new
  virtual task body();
    $display("CHECK PASS");
  endtask : body
endclass : simple_sequence
class simple_test extends uvm_test;
//Registering test
  `uvm_component_utils(simple_test)
 super.new(name, parent);
 endfunction : new
//Declare the sequence
 simple_sequence seq;
//simpleme class methods
extern virtual task main_phase(uvm_phase phase);
endclass : simple_test
task simple_test::main_phase(uvm_phase phase);
//simpl_sequence
  seq = simple_sequence::type_id::create("simple_sequence");
// SEQ
//seq = simple_sequence::type_id::create( "SEQ");
  phase. raise_objection(this);
  `uvm_info(get_full_name(), $sformatf("Running SIMPLE TEST"), UVM_MEDIUM)
  seq.start(null);
  phase.drop_objection(this);
endtask : main_phase
module m;
    run_test("simple_test");
endmodule : m
Thanks!
_[View the full topic](https://verificationacademy.com/forums/t/simulation-changing-with-respect-to-sequence-name/39476)._
