# Signal delay by X clock cycles in System Verilog
**URL:** <https://verificationacademy.com/forums/t/signal-delay-by-x-clock-cycles-in-system-verilog/31432>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, Delay, Verilog, clock, signal\
**Created:** [January 26, 2016, 2:15pm UTC](https://verificationacademy.com/forums/t/signal-delay-by-x-clock-cycles-in-system-verilog/31432 "2016-01-26T14:15:49Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![RenéPi](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/r/e47c2d/32.png) [@RenéPi](https://verificationacademy.com/forums/u/Ren%C3%A9Pi)\
**Post date:** [January 26, 2016, 2:15pm UTC](https://verificationacademy.com/forums/t/signal-delay-by-x-clock-cycles-in-system-verilog/31432/1 "2016-01-26T14:15:49Z")
</div>
Hello everyone,
I am new to Verilog.
I’d like to delay a signal by 5 clock cycles. Right now I am doing this by just copying a signal 5 times, but isn’t there a more comfortable way?
fs_shift1_model_o <= fs_model_o; //Delay for 5 clock cycles
fs_shift2_model_o <= fs_shift1_model_o; //to compare the frame syncs
fs_shift3_model_o <= fs_shift2_model_o; //of the DUT & the model
fs_shift4_model_o <= fs_shift3_model_o; //1 copy = 1 cycle
fs_shift5_model_o <= fs_shift4_model_o;
I found that there is a function named buf(x,x) (out,in) but there’s a limit, I think 1 cycle.
Thanks in advance,
René
**Post date:** [January 26, 2016, 5:05pm UTC](https://verificationacademy.com/forums/t/signal-delay-by-x-clock-cycles-in-system-verilog/31432/2 "2016-01-26T17:05:03Z")
</div>
_In reply to [RenéPi](https://verificationacademy.com/forums/t/signal-delay-by-x-clock-cycles-in-system-verilog/31432):_
```verilog
fs_shift5_model_o <= repeat (5) @(posedge clk) fs_model_o;
buf() is not a function, it is a gate-level primitive that instantiates a process.
**Post date:** [January 27, 2016, 7:52am UTC](https://verificationacademy.com/forums/t/signal-delay-by-x-clock-cycles-in-system-verilog/31432/3 "2016-01-27T07:52:34Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/signal-delay-by-x-clock-cycles-in-system-verilog/31432/2):_
thanks a lot for your answer. really appreciate your support! This works perfect, but somehow I just had to use:
fs\_shift\_model\_o \<= repeat( **4** ) @(posedge clk) fs\_model\_o;
to give me the expected result! This is way more comfortable than making several copies for a delay!
Many thank and have a nice day :)
**Author:** ![FaisalAwan](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/f/3ab097/32.png) [@FaisalAwan](https://verificationacademy.com/forums/u/FaisalAwan)\
**Post date:** [December 8, 2022, 6:04pm UTC](https://verificationacademy.com/forums/t/signal-delay-by-x-clock-cycles-in-system-verilog/31432/4 "2022-12-08T18:04:58Z")
</div>
Hope you are doing well,I have a question that if we want to make synthesizable design for N cycle delay of 32 bit signal at output then what will be the verilog code for this. I will really appreciate your answer
Thank you
**Post date:** [December 8, 2022, 8:15pm UTC](https://verificationacademy.com/forums/t/signal-delay-by-x-clock-cycles-in-system-verilog/31432/5 "2022-12-08T20:15:40Z")
</div>
_In reply to [Faisal Saeed Awan](https://verificationacademy.com/forums/t/signal-delay-by-x-clock-cycles-in-system-verilog/31432/4):_
You can use a fifo for this.
```verilog
typedef logic [31:0] uint_t;
parameter N = 5;
wire uint_t in, out;
var uint_t fifo[N];
always @(posedge clk)
     fifo[N-1] <= in;
for(genvar i=0;i<N-1;i++)
     fifo[i] <= fifo[i+1];
assign out = fifo[0];
If N is not a parameter, you will have to define a maximum number of cycle delays for the size of the fifo, and then add a mux to select where the input to each stage of the fifo comes from.
```verilog
parameter Max= 5;
int N;
var uint_t fifo[N];
for(genvar i=0;i<Max;i++)
     fifo[i] <= (i==(N-1))? in : fifo[i+1];
**Post date:** [December 9, 2022, 5:35am UTC](https://verificationacademy.com/forums/t/signal-delay-by-x-clock-cycles-in-system-verilog/31432/6 "2022-12-09T05:35:50Z")
</div>
Thank you Dave, the design code working perfectly :)
