# Set\_type\_override & set\_type\_override\_by\_type
**URL:** <https://verificationacademy.com/forums/t/set-type-override-set-type-override-by-type/36416>\
**Category:** UVM\
**Tags:** UVM, override, factory\
**Created:** [August 14, 2019, 2:28pm UTC](https://verificationacademy.com/forums/t/set-type-override-set-type-override-by-type/36416 "2019-08-14T14:28:51Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![logandeng](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/l/e9bcb4/32.png) [@logandeng](https://verificationacademy.com/forums/u/logandeng)\
**Post date:** [August 14, 2019, 2:28pm UTC](https://verificationacademy.com/forums/t/set-type-override-set-type-override-by-type/36416/1 "2019-08-14T14:28:51Z")
</div>
I’m confused about these two function, I find some codes in our project like below :
```verilog
   uvm_factory::set_type_override_by_type(packet::get_type(),mypacket::get_type());
   packet::type_id::set_type_override(mypacket::get_type());
class test_inst extend test_base
   virtual function void build_phase(uvm_phase phase)
       super.build_phase(phase);
       set_inst_override("*.seqr.*","packet","packet_me");
Frist question :
what’s the diffrent between set\_type\_override & set\_type\_override\_by\_type ???
Second question:
Factory type override syntax is :\<original\_type\>::type\_id::set\_type\_override(\<substitute\_type\>::get\_type(), replace);
Why does our project code have not “replace” ??
**Post date:** [August 16, 2019, 5:40pm UTC](https://verificationacademy.com/forums/t/set-type-override-set-type-override-by-type/36416/2 "2019-08-16T17:40:04Z")
</div>
_In reply to [L.D.2019](https://verificationacademy.com/forums/t/set-type-override-set-type-override-by-type/36416):_
They do the same thing. Don’t know why they had both. And set\_type\_override\_by\_type is not a static method, it probably was factory.set\_type\_override\_by\_type() where that needs an extra step to get a handle to the global factory.
Replace is unnecessary here, since both overrides are equivalent.
**Post date:** [August 19, 2019, 2:00am UTC](https://verificationacademy.com/forums/t/set-type-override-set-type-override-by-type/36416/3 "2019-08-19T02:00:46Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/set-type-override-set-type-override-by-type/36416/2):_
I got it.
Thank you for your explanation.
