# Set sub register block from the top register block to below component hierarchy
**URL:** <https://verificationacademy.com/forums/t/set-sub-register-block-from-the-top-register-block-to-below-component-hierarchy/40136>\
**Tags:** UVM, uvm\_reg\_block, uvm\_reg\_block-multiple-reg-blocks\
**Created:** [March 9, 2022, 10:10am UTC](https://verificationacademy.com/forums/t/set-sub-register-block-from-the-top-register-block-to-below-component-hierarchy/40136 "2022-03-09T10:10:09Z")\
**Showing post:** 2
**Post date:** [March 9, 2022, 11:03pm UTC](https://verificationacademy.com/forums/t/set-sub-register-block-from-the-top-register-block-to-below-component-hierarchy/40136/2 "2022-03-09T23:03:11Z")
_In reply to [jj\_bukhari](https://verificationacademy.com/forums/t/set-sub-register-block-from-the-top-register-block-to-below-component-hierarchy/40136):_
This is an [XY problem](https://xyproblem.info). Please explain what led you to come up with this request.
_[View the full topic](https://verificationacademy.com/forums/t/set-sub-register-block-from-the-top-register-block-to-below-component-hierarchy/40136)._
