# Sequencer
**URL:** <https://verificationacademy.com/forums/t/sequencer/38127>\
**Tags:** UVM, sequencer, sequence\
**Created:** [September 27, 2020, 10:51am UTC](https://verificationacademy.com/forums/t/sequencer/38127 "2020-09-27T10:51:50Z")\
**Showing post:** 4
**Post date:** [September 27, 2020, 2:27pm UTC](https://verificationacademy.com/forums/t/sequencer/38127/4 "2020-09-27T14:27:58Z")
_In reply to [A\_123](https://verificationacademy.com/forums/t/sequencer/38127/3):_
Typically a sequence\_item is specific to one agent. There is no reason that you can’t code your driver/monitor to act differently based upon a configuration setting. You will often see this in an agent used for a family of protocols, such as Ethernet.
If you have the same sequence\_item across several different agents, you run the risk of namespace collision and potentially using the wrong sequence\_item.
_[View the full topic](https://verificationacademy.com/forums/t/sequencer/38127)._
