# Sequence not scheduling on a proper sequencer
**URL:** <https://verificationacademy.com/forums/t/sequence-not-scheduling-on-a-proper-sequencer/29212>\
**Category:** UVM\
**Tags:** sequencer-agents, UVM, sequence\
**Created:** [March 1, 2014, 12:01am UTC](https://verificationacademy.com/forums/t/sequence-not-scheduling-on-a-proper-sequencer/29212 "2014-03-01T00:01:01Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![skumar](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/e9c0ed/32.png) [@skumar](https://verificationacademy.com/forums/u/skumar)\
**Post date:** [March 1, 2014, 12:01am UTC](https://verificationacademy.com/forums/t/sequence-not-scheduling-on-a-proper-sequencer/29212/1 "2014-03-01T00:01:01Z")
</div>
I am observing a strange problem in my environment. When driving a sequence on an array of agents. I see that sequence is driven only on first agent twice. What I have done is, I have created an agent and in my env used 2 instances of this. From my test, I have created a sequence and driven this sequence on agent[0] first and when complete(it’s blocking), I am again driving this sequence on agent[1]. But somehow, I can see that my sequence runs twice on agent[0] only.
For debug purpose, I have added a m\_sequencer.get\_full\_name print in the body task of the sequence. This is providing proper value, first print provides me agent[0] and second print provides me agent[1]. But the final task in driver which is being called for the “req” I am sending, I can see this is from agent[0] both the times.
I have used topology print hierarchy and multiple print level debugs, every thing is pointing that this sequence is supposed to run on agent[1] but, my task that is being called is always from agent[0] only.
Is there any other way, in debugging such issues. Or any possible reasons/pointers on what could have gone wrong?
Thanks in advance.
Regards,
Skumar.
**Post date:** [March 1, 2014, 12:39am UTC](https://verificationacademy.com/forums/t/sequence-not-scheduling-on-a-proper-sequencer/29212/2 "2014-03-01T00:39:41Z")
</div>
Yup, found the root cause of the issue. In my sequence, after creating a transaction i am doing shallow copy of the transaction created from test. When calling the same sequence twice on different sequencer, some how this transaction/req copy is always directed to sequence 1 only.
After removing such shallow copies from my sequence. Things work like a charm.
Hope this helps other folks. I will create a example and post it back here.
Skumar
