# Sequence Item (Transaction) Composition
**URL:** <https://verificationacademy.com/forums/t/sequence-item-transaction-composition/33549>\
**Tags:** transaction-class, UVM, constraint-randomization, extended-transaction, Sequence-Item-Composition, uvm-sequence-item\
**Created:** [September 29, 2017, 7:44pm UTC](https://verificationacademy.com/forums/t/sequence-item-transaction-composition/33549 "2017-09-29T19:44:34Z")\
**Showing post:** 17
**Author:** ![bmorris](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/bmorris/32/2097_2.png) [@bmorris](https://verificationacademy.com/forums/u/bmorris)\
**Post date:** [October 3, 2017, 2:12pm UTC](https://verificationacademy.com/forums/t/sequence-item-transaction-composition/33549/17 "2017-10-03T14:12:59Z")
_In reply to [nocsmsourabh](https://verificationacademy.com/forums/t/sequence-item-transaction-composition/33549/16):_
here’s a sim of what you are trying to do.
> **[EDA Playground](https://www.edaplayground.com/x/5wG9)**
> Edit, save, simulate, synthesize SystemVerilog, Verilog, VHDL and other HDLs from your web browser.
also, there are a few easier ways to do this. you could just put data1 and data2 into a struct; that gives you a single variable to work from. that way you dont duplicate data. You can also just put the aggregate data word, and constraint into trans1, and get rid of trans2. or, you could define a couple functions with a 16b argument for writing and reading the bytes. probably many many other ways…
_[View the full topic](https://verificationacademy.com/forums/t/sequence-item-transaction-composition/33549)._
