# Sequence Item (Transaction) Composition
**URL:** <https://verificationacademy.com/forums/t/sequence-item-transaction-composition/33549>\
**Tags:** transaction-class, UVM, constraint-randomization, extended-transaction, Sequence-Item-Composition, uvm-sequence-item\
**Created:** [September 29, 2017, 7:44pm UTC](https://verificationacademy.com/forums/t/sequence-item-transaction-composition/33549 "2017-09-29T19:44:34Z")\
**Showing post:** 16
**Post date:** [October 3, 2017, 8:37am UTC](https://verificationacademy.com/forums/t/sequence-item-transaction-composition/33549/16 "2017-10-03T08:37:09Z")
_In reply to [arun.dsouza@arm.com](https://verificationacademy.com/forums/t/sequence-item-transaction-composition/33549/15):_
This is not a really good coding style. Why do you Need to create your seq\_item explicitly in the constructor?
If you are using the `uvm\_do macros this will be done automatically in your body task.
Also when using start(item)/finish(item) there is no need to generate your seq\_item.
_[View the full topic](https://verificationacademy.com/forums/t/sequence-item-transaction-composition/33549)._
