# Sequence getting abruptly killed when configure\_phase() ends
**URL:** <https://verificationacademy.com/forums/t/sequence-getting-abruptly-killed-when-configure-phase-ends/32442>\
**Tags:** UVM, Cookbook-SequencesStopping, uvm\_sequence, main\_phase\
**Created:** [October 20, 2016, 8:42am UTC](https://verificationacademy.com/forums/t/sequence-getting-abruptly-killed-when-configure-phase-ends/32442 "2016-10-20T08:42:25Z")\
**Showing post:** 5
**Post date:** [October 20, 2016, 11:28am UTC](https://verificationacademy.com/forums/t/sequence-getting-abruptly-killed-when-configure-phase-ends/32442/5 "2016-10-20T11:28:33Z")
_In reply to [rmozhiku](https://verificationacademy.com/forums/t/sequence-getting-abruptly-killed-when-configure-phase-ends/32442/4):_
When a phase completes, all forked tasks of that phase will be killed, hence why your sequence stops.
This is one of the reasons that we recommend to only use the run\_phase(). Within the run\_phase(), use sequences to control the reset, main stimulus generation, etc. This will provide the greatest compatibility across the UVM ecosystem.
_[View the full topic](https://verificationacademy.com/forums/t/sequence-getting-abruptly-killed-when-configure-phase-ends/32442)._
