# Sampling clocking block output
**URL:** <https://verificationacademy.com/forums/t/sampling-clocking-block-output/38486>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog\
**Created:** [December 19, 2020, 10:29am UTC](https://verificationacademy.com/forums/t/sampling-clocking-block-output/38486 "2020-12-19T10:29:04Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![mseyunni](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/m/9fc29f/32.png) [@mseyunni](https://verificationacademy.com/forums/u/mseyunni)\
**Post date:** [December 19, 2020, 10:29am UTC](https://verificationacademy.com/forums/t/sampling-clocking-block-output/38486/1 "2020-12-19T10:29:04Z")
</div>
I have an interface as below:
```verilog
interface my_intf(
  input clk,
  input reset_n,
  inout ready
clocking cb_out @ (posedge clk or negedge reset_n);
   output ready;
endclocking
somewhere in my bfm, I would like to sample the ready to do some processing as below
  if(cb_out.ready)
However, I cannot do that as "sampling clocking block output is prohibited".
I was wondering if I can have another clocking block declared as below
clocking cb_in @ (posedge clk or negedge reset_n);
   input ready;
endclocking
and use it as if(cb_in.ready)....
or
simply declare a signal as below:
logical ready_internal;
assign ready_internal = ready;
and use if(my_intf.ready)..
Does both the methods work? which of these recommended and why? If both of them are not recommended, how do I fix the issue?
Madhu
**Post date:** [December 19, 2020, 4:59pm UTC](https://verificationacademy.com/forums/t/sampling-clocking-block-output/38486/2 "2020-12-19T16:59:02Z")
</div>
_In reply to [mseyunni](https://verificationacademy.com/forums/t/sampling-clocking-block-output/38486):_
There is no point in using a continuous assignment. The recommended approach is using an inout
```verilog
clocking cb_out @ (posedge clk);
   inout ready;
endclocking
Two separate clocking blocks also works.
Also note that putting
or negedge reset\_n in your clocking block event does not work the way you would want.
**Post date:** [December 19, 2020, 5:29pm UTC](https://verificationacademy.com/forums/t/sampling-clocking-block-output/38486/3 "2020-12-19T17:29:51Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/sampling-clocking-block-output/38486/2):_
Thank you Dave.
Could you elaborate on what exactly you meant by “putting or negedge reset\_n in your clocking block event does not work the way you would want.”. Sorry, I don’t think I have understood it.
**Post date:** [December 19, 2020, 7:23pm UTC](https://verificationacademy.com/forums/t/sampling-clocking-block-output/38486/4 "2020-12-19T19:23:14Z")
</div>
_In reply to [mseyunni](https://verificationacademy.com/forums/t/sampling-clocking-block-output/38486/3):_
Unlike what you are used to when writing an always block, a clocking block won’t distinguish between a clock edge and a reset event. what you might want to write instead is
```verilog
clocking cb_in @ (posedge clk iff (reset_n));
That way the clocking block inputs and outputs are always kept synchronous.
**Post date:** [December 20, 2020, 8:16am UTC](https://verificationacademy.com/forums/t/sampling-clocking-block-output/38486/5 "2020-12-20T08:16:13Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/sampling-clocking-block-output/38486/4):_
I understand. Thank you Dave.
