# Reporting of assertion coverage
**URL:** <https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757>\
**Category:** Coverage\
**Tags:** Coverage, coverage-reporting, assertion-reporting, abv, assertion-coverage\
**Created:** [April 26, 2016, 1:50pm UTC](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757 "2016-04-26T13:50:33Z")\
**Posts on this page:** 8\
**Page:** 1
<div class="post-metadata">
**Author:** ![ted.firlit](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/t/ccd318/32.png) [@ted.firlit](https://verificationacademy.com/forums/u/ted.firlit)\
**Post date:** [April 26, 2016, 1:50pm UTC](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757/1 "2016-04-26T13:50:33Z")
</div>
I have two questions related to coverage of Assertion Based Verification:
1. What is the recommended way to report and observe that all coverage is at 100% while no assertions failed and no tests failed in the scoreboard? I would prefer to see a % reported for each module in our SOC, with all three of these items combined.
2. If I am using assertions to verify some of my output signals, such as asserting that an output is 1 only when enabled, and when a timer expires, it seems to me that I also need a cover statement to ensure the inputs have been stimulated in all conditions (enable is tested both low and high, and the timer signal has been expired & non-expired). Is there some documentation with examples of best practices for assertions and the corresponding cover statements?
**Author:** ![user49](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/user49/32/4533_2.png) [@user49](https://verificationacademy.com/forums/u/user49)\
**Post date:** [April 26, 2016, 6:01pm UTC](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757/2 "2016-04-26T18:01:59Z")
</div>
_In reply to [ted.firlit](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757):_
I see three ways to get coverage information:
1. While in simulation, the tool (most, if not all simulators) provide those statistics.
2. During the simulation run command, most tools provide a coverage report command that you can fire with various options. From Questa’s documentation, “_The coverage report command produces textual output of coverage statistics or exclusions (e.g., assertions and cover groups). By default, the command prints results to the Transcript window, and returns an empty string. You can use the -file argument to save the output to a file_”. See your simulator documentation for the specific command and options; this forum tries to be vendor independent, thus I won’t discuss the specifics.
3. Use APIs. I address this topic in my book [SVA Handbook 4th Edition, 2016 ISBN 978-1518681448](http://goo.gl/JOfuEB). I am making those pages available at [Functional coverage in verification](http://SystemVerilog.us/svabk4_cvg2.pdf). Code is provided in those pages.
> 1. If I am using assertions to verify some of my output signals, such as asserting that an output is 1 only when enabled, and when a timer expires, it seems to me that I also need a cover statement to ensure the inputs have been stimulated in all conditions (enable is tested both low and high, and the timer signal has been expired & non-expired). Is there some documentation with examples of best practices for assertions and the corresponding cover statements?
- _Asserting that an output is 1 only when enabled, and when a timer expires_
- [Ben] That’s an assertion
- _a cover statement to ensure the inputs have been stimulated in all conditions (enable is tested both low and high, and the timer signal has been expired & non-expired._
- [Ben] That looks like cover sequence of several types of sequences.
[http://www.systemverilog.us/](http://www.systemverilog.us/) [ben@systemverilog.us](mailto:ben@systemverilog.us)
- [SVA Handbook 4th Edition, 2016 ISBN 978-1518681448](http://goo.gl/JOfuEB)
- A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
- Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
- Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 0-9705394-2-8
- Component Design by Example ", 2001 ISBN 0-9705394-0-1
- VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
- VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
**Post date:** [April 28, 2016, 2:37pm UTC](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757/3 "2016-04-28T14:37:25Z")
</div>
_In reply to [ben@SystemVerilog.us](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757/2):_
Hi Ben,
Thanks for the response. Good info on API’s. I was hoping not to have to customize my reporting, since it seems like a common task that Questa should roll up all coverage and assertion grading into a single number per module, so I can scan a report and see the complete status of each module in one column, including coverage and test failures. I think I’ll take my first question over to a Modelsim/Questa support site.
My second question again seems like a common problem which I assume someone should have written a page of documentation regarding pairing assertions and cover statements, where the cover statements ensure the inputs to the logic are stimulated for all cases, and the assertion ensures that the outputs are correct for the given input conditions. Am I using assertions in a non-standard way? Or perhaps this is a basic occurrence which requires no detailed discussion. I was hoping to glean some hints on a “formula” for ensuring that I don’t miss something in my cover statement, based on a given assertion statement.
Thanks for your time!
**Post date:** [April 28, 2016, 3:38pm UTC](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757/4 "2016-04-28T15:38:55Z")
</div>
_In reply to [ted.firlit](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757/3):_
> _In reply to [ben@SystemVerilog.us](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757/3):_
That might be your lucky day :)
It turns out that I did address this topic in my SVA Handbook 4th Edition; link provides pages from that book.
[SystemVerilog.us/svabk4\_coverage.pdf](http://SystemVerilog.us/svabk4_coverage.pdf)
Keep in mind that tools provide some coverage statistics on assertions (oassed, failed), but the cover property provides a more (see the pdf file).
**Post date:** [April 28, 2016, 6:20pm UTC](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757/5 "2016-04-28T18:20:45Z")
</div>
_In reply to [ben@SystemVerilog.us](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757/4):_
Thanks Ben, indeed your paper does address my concern that both assertions and coverage need to be evaluated before considering a design verification “covered”. Your API example might be the best way to coordinate both of these reports, as you point out it is then simulator-independent. I’m still hoping that I find out that Questa has a way to combine the two results without using an API…
**Post date:** [April 28, 2016, 6:26pm UTC](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757/6 "2016-04-28T18:26:29Z")
</div>
_In reply to [ted.firlit](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757/5):_
Glad the pages I provided from my SVA book were helpful.
- SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
**Post date:** [April 29, 2016, 8:16pm UTC](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757/7 "2016-04-29T20:16:19Z")
</div>
Ben,
A suggestion for your next edition of your book-- add a few examples of an assertion and a related cover statement, so that the reader gets the idea of how the two are related. Then someone might more easily see the benefit of using your API to combine the two under a combined reporting number.
Other readers using Questasim (who are as naive as I am about coverage reporting):
I did locate Questasim User Manual documentation regarding Aggregate coverage reporting (cover + assertion reporting), in the Coverage Aggregation link found here:
[https://supportnet.mentor.com/docs/201604008/docs/htmldocs/mgchelp.htm#context=questa\_sim\_user&id=960&tag=id52585b19-cb2f-417e-9962-73172199ae8b](https://supportnet.mentor.com/docs/201604008/docs/htmldocs/mgchelp.htm#context=questa_sim_user&id=960&tag=id52585b19-cb2f-417e-9962-73172199ae8b)
The “coverage binning and calculation” page linked within the “calculation and total coverage” from the above page states that assertions are aggregated as they do not fail and occur non-vacuously.
Make sure to enable Structure\>Code\_Coverage\>Enable\_Recursive\_Coverage\_Sums for hierarchical accumulation of coverage.
The columns can be enabled in the Structure pane by right-clicking in a column heading, and select “Change Column Visibility”.
I found these columns useful: Instance, Visibility, Top Category, Total Coverage, Cover%, Assertion%, Covers hit, Covers Missed, Cover graph, Assertions hit, Assertions missed, Assertion graph.
Your structure pane settings can be saved by right-clicking in a column heading, select “Export Column Configurations.”
I also checked that a merged UCDB can indeed be displayed with the expanded-columns Structure pane. Very nice.
**Post date:** [April 30, 2016, 3:01am UTC](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757/8 "2016-04-30T03:01:13Z")
</div>
_In reply to [ted.firlit](https://verificationacademy.com/forums/t/reporting-of-assertion-coverage/31757/7):_
Since you’re getting a deep assertion coverage experience on a complex design, I strongly suggest that you write a paper on this topic. Yo can show this paper at the Verification Horizons, or at a DVCon, or at other seminars.
Do consider it!
Ben
