# Related to associative array
**URL:** <https://verificationacademy.com/forums/t/related-to-associative-array/34689>\
**Category:** UVM\
**Tags:** UVM, accessing-the-associative-array-elements\
**Created:** [July 17, 2018, 7:39am UTC](https://verificationacademy.com/forums/t/related-to-associative-array/34689 "2018-07-17T07:39:17Z")\
**Posts on this page:** 14\
**Page:** 1
<div class="post-metadata">
**Author:** ![shipratripathi](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/e47c2d/32.png) [@shipratripathi](https://verificationacademy.com/forums/u/shipratripathi)\
**Post date:** [July 17, 2018, 7:39am UTC](https://verificationacademy.com/forums/t/related-to-associative-array/34689/1 "2018-07-17T07:39:17Z")
</div>
hi
i am using bit[31:0]mem[int] to create associative memory in a storage class. and trying to call the data stored in storage class in driver.
how do i call as i am calling
```verilog
addrr=raddr_q.pop_back();
class_name_handle.mem[addrr]
showing error
Unresolved reference to ‘mem’ in $root.mem.
is there any solution calling associative array from other class to driver class?
**Post date:** [July 17, 2018, 7:46am UTC](https://verificationacademy.com/forums/t/related-to-associative-array/34689/2 "2018-07-17T07:46:59Z")
</div>
_In reply to [Er. Shipra](https://verificationacademy.com/forums/t/related-to-associative-array/34689):_
Two things:
(1) you are calling the method pop\_back which is not defined on an assiciative array.
(2) You should show the code which causes the error.
**Post date:** [July 17, 2018, 7:51am UTC](https://verificationacademy.com/forums/t/related-to-associative-array/34689/3 "2018-07-17T07:51:23Z")
</div>
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/related-to-associative-array/34689/2):_
hi
storage strg;
int RADDR\_Q[$];
i am getting this class in driver and using it.
addrr=RADDR\_Q.pop\_back();
if(strg.mem.exists(addrr))
$display(“memory”,mem);
vif.rdata\<=strg.mem[addrr];
**Post date:** [July 17, 2018, 8:14am UTC](https://verificationacademy.com/forums/t/related-to-associative-array/34689/4 "2018-07-17T08:14:23Z")
</div>
_In reply to [Er. Shipra](https://verificationacademy.com/forums/t/related-to-associative-array/34689/3):_
To clarify:
You do not show what storage is.
RADDR\_Q is a queue. Then pop\_back is fine.
Where is the associative aray?
**Post date:** [July 17, 2018, 8:24am UTC](https://verificationacademy.com/forums/t/related-to-associative-array/34689/5 "2018-07-17T08:24:52Z")
</div>
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/related-to-associative-array/34689/4):_
hi
here is the code
```verilog
class axi_storage extends uvm_component;
  `uvm_component_utils(axi_storage)
 bit[31:0]mem[int];
    super.new(name,parent);
endclass :axi_storage
driver class:-
```verilog
class axi_driver extends uvm_driver#(axi_transaction);
 axi_storage strg;
  bit[31:0] dwdataQ1 [31:0];
  int ADDR_Q[$]; int RADDR_Q[$];
if(!uvm_config_db#(axi_storage)::get(this,"*","axi_storage",strg))
		`uvm_fatal("NO_AGNT_CFG",{"storage must be set for:",get_full_name(),".strg"})
if(cfg.master_slave_select == AXI_MASTER)
		for(int j=0;j<=tx.wlen;j++)
						@(posedge vif.aclk);
						addr=ADDR_Q.pop_back;
						strg.mem[addr]=dwdataQ1[j];
if(cfg.master_slave_select == AXI_SLAVE)
		for(int i=0;i<=tx.rlen;i++)
													$display("\tQueue_1 size in read data is %0d",RADDR_Q.size());
													addrr=RADDR_Q.pop_back();
													$display("memory",mem);
													vif.rdata<=strg.mem[addrr];
**Post date:** [July 17, 2018, 8:28am UTC](https://verificationacademy.com/forums/t/related-to-associative-array/34689/6 "2018-07-17T08:28:01Z")
</div>
_In reply to [Er. Shipra](https://verificationacademy.com/forums/t/related-to-associative-array/34689/5):_
hi, this is snapshot of my code,
q:-do i need to collect it from monitor, if yes how?
**Post date:** [July 17, 2018, 8:48am UTC](https://verificationacademy.com/forums/t/related-to-associative-array/34689/7 "2018-07-17T08:48:52Z")
</div>
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/related-to-associative-array/34689/6):_
hi
error was because or this line, but still i am not getting my data, it is zero only
**Post date:** [July 17, 2018, 9:15am UTC](https://verificationacademy.com/forums/t/related-to-associative-array/34689/8 "2018-07-17T09:15:36Z")
</div>
_In reply to [Er. Shipra](https://verificationacademy.com/forums/t/related-to-associative-array/34689/7):_
In your driver you do a get on the config\_db
if(!uvm\_config\_db#(axi\_storage)::get(this,“\*”,“axi\_storage”,strg))
to retrieve the object of your storage from the config\_db. Where are you doing the set of this object?
**Post date:** [July 17, 2018, 9:36am UTC](https://verificationacademy.com/forums/t/related-to-associative-array/34689/9 "2018-07-17T09:36:57Z")
</div>
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/related-to-associative-array/34689/8):_
hi
in agent…
class axi\_agent extends uvm\_agent;
axi\_storage strg;
function new(string name,uvm\_component parent);
strg = axi_storage::type_id::create("strg",this);
uvm_config_db#(axi_storage)::set(this,"*","axi_storage",strg);
**Post date:** [July 17, 2018, 11:26am UTC](https://verificationacademy.com/forums/t/related-to-associative-array/34689/10 "2018-07-17T11:26:12Z")
</div>
_In reply to [Er. Shipra](https://verificationacademy.com/forums/t/related-to-associative-array/34689/9):_
For me it is totally unclear in which tasks/function you are doing what.
Does this code belong to your run\_task in the driver?
```verilog
**Post date:** [July 17, 2018, 11:46am UTC](https://verificationacademy.com/forums/t/related-to-associative-array/34689/11 "2018-07-17T11:46:16Z")
</div>
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/related-to-associative-array/34689/10):_
hi
yes
i made task and calling these task in run
one task is controlled by master and other is by slave
this is my write task in master:-
```verilog
this is my read task by slave
```verilog
these are two tasks,write and read. but master and slave can’t see each other as controlled by configuration. so, i amde a separate class visible to both, and i am writing on it
but still slave is not able to get the data
**Post date:** [July 17, 2018, 6:11pm UTC](https://verificationacademy.com/forums/t/related-to-associative-array/34689/12 "2018-07-17T18:11:39Z")
</div>
_In reply to [Er. Shipra](https://verificationacademy.com/forums/t/related-to-associative-array/34689/11):_
You want to share 1 resource between 2 different components (master and slave). Is this what you want to do?
**Post date:** [July 18, 2018, 10:53am UTC](https://verificationacademy.com/forums/t/related-to-associative-array/34689/13 "2018-07-18T10:53:34Z")
</div>
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/related-to-associative-array/34689/12):_
HI
yes
i want the same
**Post date:** [July 18, 2018, 1:12pm UTC](https://verificationacademy.com/forums/t/related-to-associative-array/34689/14 "2018-07-18T13:12:18Z")
</div>
_In reply to [Er. Shipra](https://verificationacademy.com/forums/t/related-to-associative-array/34689/13):_
There are di8fferent solutions possible. In my eyes the most elegant solution is the
```verilog
uvm_queue
See the UVM Reference Manual for the detail
