# Regarding Sequence issue related to UVM1.2
**URL:** <https://verificationacademy.com/forums/t/regarding-sequence-issue-related-to-uvm1-2/36991>\
**Tags:** UVM\_INFO-packet\_sequencesv38--0-uvm\_test\_topeagseqrpacket\_sequence-TRACE-unitpacket\_sequencebody-wait-grant, UVM, sequence, UVM12\
**Created:** [January 6, 2020, 6:12pm UTC](https://verificationacademy.com/forums/t/regarding-sequence-issue-related-to-uvm1-2/36991 "2020-01-06T18:12:56Z")\
**Showing post:** 3
**Author:** ![sravankumarpothu](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/bb73d2/32.png) [@sravankumarpothu](https://verificationacademy.com/forums/u/sravankumarpothu)\
**Post date:** [January 7, 2020, 1:01pm UTC](https://verificationacademy.com/forums/t/regarding-sequence-issue-related-to-uvm1-2/36991/3 "2020-01-07T13:01:38Z")
_In reply to [cgales](https://verificationacademy.com/forums/t/regarding-sequence-issue-related-to-uvm1-2/36991/2):_
Hi cgales,Thank you for your response.
Already I made all these changes and tried even though it is not working in UVM1.2 and it is giving the same result as before.
Below i am sharing the code which i have modified, If any mistakes i did please let me know.
```verilog
class packet_sequence extends uvm_sequence # (packet);
  `uvm_object_utils(packet_sequence)
  function new (string name = "packet_sequence");
    super.new(name);
    `uvm_info("packet_sequence",$sformatf("%m"),UVM_MEDIUM);
  task body();
    `uvm_info("TRACE",$sformatf("%m"),UVM_MEDIUM);
    `uvm_info("TRACE",$sformatf("%m 11111111111"),UVM_MEDIUM);
    if (starting_phase != null)
      starting_phase.raise_objection(this);
    repeat(5)
        req = packet::type_id::create("req");
        `uvm_info("TRACE",$sformatf("%m wait grant"),UVM_MEDIUM);
         start_item(req);
        `uvm_info ("SEQ", $sformatf("start_item() fn call done"), UVM_MEDIUM)
         req.randomize();
         finish_item(req);
      starting_phase.drop_objection(this);
      `uvm_info("TRACE",$sformatf("%m 77777777777"),UVM_MEDIUM);
class test extends uvm_test;
  `uvm_component_utils(test)
  env e ;
  packet_sequence p_seq;
  uvm_sequencer #(packet) p_seqr0;
  //uvm_factory factory;
  //uvm_coreservice_t cs = uvm_coreservice_t::get();
  function new(string name,uvm_component parent);
    super.new(name,parent);
    `uvm_info("test",$sformatf("%m"),UVM_MEDIUM);
  endfunction : new
    super.build_phase(phase);
    e=env::type_id::create("e",this);
    p_seqr0 = uvm_sequencer#(packet)::type_id::create ("p_seqr0", this);
  endfunction : build_phase
  function void start_of_simulation_phase (uvm_phase phase);
    super.start_of_simulation_phase(phase);
    uvm_top.print_topology();
  // factory.print();
  endfunction : start_of_simulation_phase
      p_seq=packet_sequence::type_id::create("p_seq",this);
 	  p_seq.start(p_seqr0);
class driver extends uvm_driver # (packet);
  `uvm_component_utils(driver);
    virtual add_sub_if vif;
    `uvm_info("drv",$sformatf("%m"),UVM_MEDIUM);
  function void build_phase (uvm_phase phase );
    uvm_config_db # (virtual add_sub_if) :: get (this, "", "add_sub_if",vif);
    super.run_phase(phase);
    vif.a=0;
    vif.b=0;
    vif.doAdd=0;
    forever
        //for the above line we are getting a cross module reference error .
        `uvm_info ("DRIVER", $sformatf ("Waiting for data from sequencer"), UVM_MEDIUM);
        seq_item_port.get_next_item(req);
        `uvm_info ("DRIVER", $sformatf ("Getting data"), UVM_MEDIUM);
    // @(negedge vif.clk);
        send();
       // this.print();
        req.print();
        //this.print();
        seq_item_port.item_done();
        `uvm_info ("DRIVER", $sformatf ("Driver task done"), UVM_MEDIUM);
  task send ();
    vif.a<=req.a;
    vif.b<=req.b;
    vif.doAdd<=req.doAdd;
## Result: UVM\_INFO driver.sv(43) @ 0: uvm\_test\_top.e.ag.drv [DRIVER] Waiting for data from sequencer UVM\_INFO packet\_sequence.sv(7) @ 0: reporter@@p\_seq [packet\_sequence] $unit::\packet\_sequence::new UVM\_INFO packet\_sequence.sv(11) @ 0: uvm\_test\_top.p\_seqr0@@p\_seq [TRACE] $unit::\packet\_sequence::body UVM\_INFO packet\_sequence.sv(12) @ 0: uvm\_test\_top.p\_seqr0@@p\_seq [TRACE] $unit::\packet\_sequence::body 11111111111 UVM\_INFO packet.sv(20) @ 0: reporter@@req [packet] $unit::\packet::new UVM\_INFO packet\_sequence.sv(21) @ 0: uvm\_test\_top.p\_seqr0@@p\_seq [TRACE] $unit::\packet\_sequence::body wait grant UVM\_INFO packet\_sequence.sv(7) @ 0: reporter@@packet\_sequence [packet\_sequence] $unit::\packet\_sequence::new UVM\_INFO packet\_sequence.sv(11) @ 0: uvm\_test\_top.e.ag.seqr@@packet\_sequence [TRACE] $unit::\packet\_sequence::body UVM\_INFO packet\_sequence.sv(12) @ 0: uvm\_test\_top.e.ag.seqr@@packet\_sequence [TRACE] $unit::\packet\_sequence::body 11111111111 UVM\_INFO packet.sv(20) @ 0: reporter@@req [packet] $unit::\packet::new UVM\_INFO packet\_sequence.sv(21) @ 0: uvm\_test\_top.e.ag.seqr@@packet\_sequence [TRACE] $unit::\packet\_sequence::body wait grant UVM\_INFO packet\_sequence.sv(23) @ 0: uvm\_test\_top.e.ag.seqr@@packet\_sequence [SEQ] start\_item() fn call done UVM\_INFO driver.sv(46) @ 0: uvm\_test\_top.e.ag.drv [DRIVER] Getting data
## Name Type Size Value
## req packet - @829 a integral 8 'h4 b integral 8 'h2 doAdd integral 1 'h1 begin\_time time 64 0 depth int 32 'd2 parent sequence (name) string 15 packet\_sequence parent sequence (full name) string 38 uvm\_test\_top.e.ag.seqr.packet\_sequence sequencer string 22 uvm\_test\_top.e.ag.seqr
## UVM\_INFO driver.sv(55) @ 0: uvm\_test\_top.e.ag.drv [DRIVER] Driver task done UVM\_INFO driver.sv(43) @ 0: uvm\_test\_top.e.ag.drv [DRIVER] Waiting for data from sequencer UVM\_INFO packet.sv(20) @ 0: reporter@@req [packet] $unit::\packet::new UVM\_INFO packet\_sequence.sv(21) @ 0: uvm\_test\_top.e.ag.seqr@@packet\_sequence [TRACE] $unit::\packet\_sequence::body wait grant UVM\_INFO packet\_sequence.sv(23) @ 0: uvm\_test\_top.e.ag.seqr@@packet\_sequence [SEQ] start\_item() fn call done UVM\_INFO driver.sv(46) @ 0: uvm\_test\_top.e.ag.drv [DRIVER] Getting data
## req packet - @846 a integral 8 'h3 b integral 8 'h1 doAdd integral 1 'h1 begin\_time time 64 0 depth int 32 'd2 parent sequence (name) string 15 packet\_sequence parent sequence (full name) string 38 uvm\_test\_top.e.ag.seqr.packet\_sequence sequencer string 22 uvm\_test\_top.e.ag.seqr
Execution interrupted or reached maximum runtime.
Done
_[View the full topic](https://verificationacademy.com/forums/t/regarding-sequence-issue-related-to-uvm1-2/36991)._
