# Reg\_model predefine reset regs value check error (quirky register?)
**URL:** <https://verificationacademy.com/forums/t/reg-model-predefine-reset-regs-value-check-error-quirky-register/31837>\
**Category:** UVM\
**Tags:** uvm\_reg\_map, UVM\
**Created:** [May 19, 2016, 5:24pm UTC](https://verificationacademy.com/forums/t/reg-model-predefine-reset-regs-value-check-error-quirky-register/31837 "2016-05-19T17:24:00Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![Levard](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/l/85e7bf/32.png) [@Levard](https://verificationacademy.com/forums/u/Levard)\
**Post date:** [May 19, 2016, 5:24pm UTC](https://verificationacademy.com/forums/t/reg-model-predefine-reset-regs-value-check-error-quirky-register/31837/1 "2016-05-19T17:24:00Z")
</div>
Hello everyone!
Practising uvm with i2c device. It has registers like this:
i2c\_reg\_map.add\_reg ( I2C\_PRERlo\_reg , 3’b000 , “RW” );
i2c\_reg\_map.add\_reg ( I2C\_PRERhi\_reg , 3’b001 , “RW” );
i2c\_reg\_map.add\_reg ( I2C\_CTR\_reg , 3’b010 , “RW” );
**i2c\_reg\_map.add\_reg ( I2C\_TXR\_reg , 3’b011 , “WO” );
i2c\_reg\_map.add\_reg ( I2C\_RXR\_reg , 3’b011 , “RO” );
i2c\_reg\_map.add\_reg ( I2C\_CR\_reg , 3’b100 , “WO” );
i2c\_reg\_map.add\_reg ( I2C\_SR\_reg , 3’b100 , “RO” );**
2 registers have same address but changes its values if you write or read to/from them
So, i try predefine sequense **uvm\_reg\_hw\_reset\_seq** and in log i see:
> %I-( uvm\_reg\_hw\_reset\_seq.svh: 115) [uvm\_reg\_hw\_reset\_seq] { 9500} Verifying reset value of register reg\_model.I2C\_TXR\_reg in map “reg\_model.i2c\_reg\_map”…
> %E-(\_\_\_\_\_\_\__**uvm\_reg\_cbs.svh:482)[UVM/REG/WRTEONLY**]_{\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_9500} reg\_model.I2C\_TXR\_reg is write-only. Cannot call read() method.
> %E-(\_uvm\_reg\_hw\_reset\_seq.svh:\__122)[uvm\_reg\_hw\_reset\_seq]_{\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_\_9500} Status was UVM\_NOT\_OK when reading reset value of register “reg\_model.I2C\_TXR\_reg” through map “reg\_model.i2c\_reg\_map”.
Sequence try to read from WO register, but it shouldn’t do it.
How to solve this error?
**Author:** ![dhserfer](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/d/a9a28c/32.png) [@dhserfer](https://verificationacademy.com/forums/u/dhserfer)\
**Post date:** [May 19, 2016, 10:52pm UTC](https://verificationacademy.com/forums/t/reg-model-predefine-reset-regs-value-check-error-quirky-register/31837/2 "2016-05-19T22:52:08Z")
</div>
_In reply to [Levard](https://verificationacademy.com/forums/t/reg-model-predefine-reset-regs-value-check-error-quirky-register/31837):_
See Section 27.2 of the Class Reference Manual 1.2, it describes how to exclude a register or register block with:
uvm\_resource\_db#(bit)::set({“REG::”,regmodel.blk.get\_full\_name(),“.\*”},“NO\_REG\_HW\_RESET\_TEST”, 1, this);
**Post date:** [May 20, 2016, 9:02am UTC](https://verificationacademy.com/forums/t/reg-model-predefine-reset-regs-value-check-error-quirky-register/31837/3 "2016-05-20T09:02:25Z")
</div>
_In reply to [dhserfer](https://verificationacademy.com/forums/t/reg-model-predefine-reset-regs-value-check-error-quirky-register/31837/2):_
Thanks, it works for me, but is this the only decision? Other way to write “quirky\_register”?
