# Re: Some challenging assertions involving dynamic ranges
**URL:** <https://verificationacademy.com/forums/t/re-some-challenging-assertions-involving-dynamic-ranges/30076>\
**Category:** SystemVerilog\
**Tags:** SVA-Assertion, SystemVerilog\
**Created:** [October 30, 2014, 4:56am UTC](https://verificationacademy.com/forums/t/re-some-challenging-assertions-involving-dynamic-ranges/30076 "2014-10-30T04:56:59Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![user49](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/user49/32/4533_2.png) [@user49](https://verificationacademy.com/forums/u/user49)\
**Post date:** [October 30, 2014, 4:56am UTC](https://verificationacademy.com/forums/t/re-some-challenging-assertions-involving-dynamic-ranges/30076/1 "2014-10-30T04:56:59Z")
</div>
```auto
module some_asn;
	bit a, b, clk;
	bit[15:0] x=3, y=5; // // X and Y can be varying per simulation to simulation
	// 1) Signal B must remain constant during the entire time A signal is asserted
	ap_ab: assert property(@(posedge clk) a |-> b);
	// 2) A asserts,
	// B if asserts it should assert within X cycles of A
	// and should remain asserted as long a A asserts
	property p_axb;
		bit[15:0] v_x;
		($rose(a), v_x=x) |=>
		      first_match((1, v_x=v_x-1'b1)[*1:$] ##1 (b && v_x >=0)) |->
		          (b && a)[*1:$] ##1 !a;
	ap_axb:assert property(@(posedge clk) p_axb);
	// *****NOTE*****
        // If ‘b’ is never true, a simulator will keep on evaluating the sequence
        // inside the first_match() once $rose(a) is true.
	// A solution
	property p_axb2;
		bit[15:0] v_x;
		   first_match(
		   	            ((1, v_x=v_x-1'b1)[*1:$] ##1 (b && v_x >=0)) or
                                    (v_x < 0 [->1])
	ap_axb2:assert property(@(posedge clk) p_axb2);
    // 3) if asserts A should stay asserted for a min of X cyles and stay upto a max of Y cycles
	property p_axy;
		bit[15:0] v_x, v_y;
		($rose(a), v_x=x, v_y=y) |=>
		      first_match((a, v_x=v_x-1'b1, v_y=v_y-1'b1)[*1:$] ##1 v_x ==0) |->
		           (a, v_y=v_y-1'b1) [*1:$] ##1 !a && v_y >=0 ;
	ap_axy:assert property(@(posedge clk) p_axy);
Ben Cohen [systemverilog.us](http://systemverilog.us)
