# Randomization with uvm\_do\_with
**URL:** <https://verificationacademy.com/forums/t/randomization-with-uvm-do-with/38913>\
**Category:** UVM\
**Tags:** UVM, uvm\_do\_with, randomization\
**Created:** [March 29, 2021, 7:14am UTC](https://verificationacademy.com/forums/t/randomization-with-uvm-do-with/38913 "2021-03-29T07:14:09Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![kritikagoell](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/k/ebca7d/32.png) [@kritikagoell](https://verificationacademy.com/forums/u/kritikagoell)\
**Post date:** [March 29, 2021, 7:14am UTC](https://verificationacademy.com/forums/t/randomization-with-uvm-do-with/38913/1 "2021-03-29T07:14:09Z")
</div>
I was trying to randomize the the order of read and write through uvm\_do\_with. In the following code
1.class ahb\_wr\_rd\_seqs extends ahb\_base\_seq;
2. `uvm\_object\_utils(ahb\_wr\_rd\_seqs)
3. function new(string name=“”);
4. super.new(name);
5. endfunction
1. task body();
2. repeat(5) begin
3. `uvm\_do\_with(req, {req.wr\_rd ==1;})
4. `uvm\_do\_with(req, {req.wr\_rd ==0;})
5. end
6. endtask
12.endclass
The order of execution will be 5 write followed by 5 read. Is there any way of randomizing the order of execution here itself?
Regards
**Post date:** [March 29, 2021, 10:42am UTC](https://verificationacademy.com/forums/t/randomization-with-uvm-do-with/38913/2 "2021-03-29T10:42:43Z")
</div>
_In reply to [pankajpattel](https://verificationacademy.com/forums/t/randomization-with-uvm-do-with/38913):_
You do not randomize the access write/read. You are setting corresponding constraints.
It should start with a write followed by a read 5 times.
If you want to randomize the access use simply
```verilog
task body();
 repeat(10) begin
 `uvm_do(req)
**Post date:** [March 29, 2021, 12:26pm UTC](https://verificationacademy.com/forums/t/randomization-with-uvm-do-with/38913/3 "2021-03-29T12:26:30Z")
</div>
Thanks chr\_sue. It helped.
Regards
