# Question on Inheritance in SV
**URL:** <https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, Inheritance\
**Created:** [December 6, 2017, 5:18pm UTC](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787 "2017-12-06T17:18:54Z")\
**Posts on this page:** 14\
**Page:** 1
<div class="post-metadata">
**Author:** ![soumyarayaprolu](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/a698b9/32.png) [@soumyarayaprolu](https://verificationacademy.com/forums/u/soumyarayaprolu)\
**Post date:** [December 6, 2017, 5:18pm UTC](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/1 "2017-12-06T17:18:54Z")
</div>
Can anyone explain why I am getting a as 0 in the below example:
```verilog
class C;
   int c1 = 1;
   int c2 = 1;
   int c3 = 1;
function new(int a);
   $display("ZAM: a_val: %d",a); // always getting display as 0
   c2 = 2;
   c3 = a;
class D extends C;
   int d1 = 4;
   int d2 = c2;
   int d3 = 6;
function new;
   super.new(d3);
D d1=new();
P.S; When I replace int d3=6; with **static** int d3 =6; then I am able to get value of a as 0 (in base class constructor function)
**Author:** ![LinaLin20](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/l/34f0e0/32.png) [@LinaLin20](https://verificationacademy.com/forums/u/LinaLin20)\
**Post date:** [December 6, 2017, 5:39pm UTC](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/2 "2017-12-06T17:39:02Z")
</div>
_In reply to [soumyarayaprolu](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787):_
This is the example in SV LRM 8.7 Constructors chapter. It describes how class construct is executed in order. In this example, when calling super.new(d3), the value of d3 is undefined because d3 variable initialization is done in step 2) after new method executed.
1. The new method of a derived class shall **first call its base class constructor** [super.new() as described.
2)**After the base class constructor call (if any) has completed**, **each property defined in the class shall be initialized** to its explicit default value or its uninitialized value if no default is provided.
2. After the properties are initialized, **the remaining code in a user-defined constructor shall be evaluated.**
**Post date:** [December 6, 2017, 5:49pm UTC](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/3 "2017-12-06T17:49:01Z")
</div>
_In reply to [Lina.Lin](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/2):_
Thanks for your reply. Cna you also help me understand the below point:
When I replace int d3=6; with static int d3 =6; then I am able to get value of a as 0 (in base class constructor function)
**Post date:** [December 6, 2017, 6:28pm UTC](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/4 "2017-12-06T18:28:59Z")
</div>
_In reply to [soumyarayaprolu](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/3):_
> When I replace int d3=6; with static int d3 =6; then I am able to get value of **a as 0** (in base class constructor function)
Your question regarding to **a as 0** here is confused. I guess you want to ask that **a is 6** when **static int d3=6;**
static property of the class is **shared** by all of its instances. it can be accessed by **class scope resolution operator ::** directly like D::d3 even though no class instance. So I think static variable’s initialization to explicit default value is before the class instance new() construct.
**Post date:** [December 6, 2017, 6:29pm UTC](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/5 "2017-12-06T18:29:51Z")
</div>
_In reply to [soumyarayaprolu](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/4):_
Because all variables with static lifetimes get initialized before any initial or always block processes start.
You actually have a race condition because the order of static variable initialization is not defined. Your d1 variable inside the initial block is also a static variable that gets initialized before the initial block process starts. A simulator that follows the 1800-2012 would have made this an error (Section 6.21). For backward compatibility with Verilog, variables declared inside a procedural block that is not a class method have a default static lifetime. SystemVerilog requires you to remove the static variable initialization, or declare the variable explicitly static to make sure you have the right intent.
**Author:** ![saurabh\_3](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/saurabh_3/32/3027_2.png) [@saurabh\_3](https://verificationacademy.com/forums/u/saurabh_3)\
**Post date:** [December 7, 2017, 5:10am UTC](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/6 "2017-12-07T05:10:36Z")
</div>
_In reply to [soumyarayaprolu](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/5):_
```verilog
class C;
int c1 = 1;
int c2 = 1;
int c3 = 1;
c2 = 2;
c3 = a;
class D extends C;
int d1 = 4;
int d2 = c2;
int d3 = 6;
function new;
super.new(d3);
D d1=new();
But when running both the cases a is getting value of 6.
**Post date:** [December 7, 2017, 5:41am UTC](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/7 "2017-12-07T05:41:31Z")
</div>
_In reply to [saurabh\_3](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/6):_
I update your code to have d3 as static, d4 as non-static and pass them to new(a,b). The sim result show display message as below. Not sure why you get 0 for both cases.
ZAM: **static a\_val: 6** non-static b\_val:0
```verilog
class C;
   int c1 = 1;
   int c2 = 1;
   int c3 = 1;
  function new(int a, int b);
    $display("ZAM: static a_val: %0d non-static b_val:%0d",a,b); // always getting display as 0
   c2 = 2;
   c3 = a;
class D extends C;
   int d1 = 4;
   int d2 = c2;
   static int d3 = 6;
          int d4 = 6;
function new;
  super.new(d3,d4);
D d1;
  d1=new();
**Author:** ![srbeeram](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/s/d07c76/32.png) [@srbeeram](https://verificationacademy.com/forums/u/srbeeram)\
**Post date:** [December 7, 2017, 5:50am UTC](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/8 "2017-12-07T05:50:58Z")
</div>
_In reply to [saurabh\_3](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/7):_
Hi could you please clarify the following.
I am assuming that memory for the class properties is created when constructor is called. then how we are able to call super.new(d3) with d3 variable as memory for d3 is not created yet when d3 variable is not declared as static.
1. when d3 variable is declared as static, what is the order of memory creation and initialization. is memory created first for all static variables and then initialization happens for all static variables . or memory created for one variable and it gets initialized, if this is true ,how d3 variable is accessed even when d3 is declared as static as it is not created still.
**Post date:** [December 7, 2017, 6:34am UTC](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/9 "2017-12-07T06:34:56Z")
</div>
_In reply to [Lina.Lin](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/8):_
> _In reply to [saurabh\_3](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/8):_
```verilog
class C;
int c1 = 1;
int c2 = 1;
int c3 = 1;
c2 = 2;
c3 = a;
class D extends C;
int d1 = 4;
int d2 = c2;
static int d3 = 6;
int d4 = 6;
function new;
super.new(d3,d4);
D d1;
d1=new();
I am using vcs tool for your updated code ,getting result as
ZAM: static a\_val: 6 non-static b\_val:6
V C S S i m u l a t i o n R e p o r t
**Post date:** [December 7, 2017, 6:59am UTC](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/10 "2017-12-07T06:59:19Z")
</div>
_In reply to [srbeeram](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/9):_
The space for any variable, static or non-static, gets allocated and initialized with its default value in time for you to reference it. SV does not allow you to reference a variable that does not exist.
The variable’s lifetime determines when the optional initialization expression gets evaluated.
static: before any initial or always processes begin
automatic: upon entering the procedural block where the variable is declared
dynamic: prior to the body of the class constructor where the variable is declared.
**Post date:** [December 7, 2017, 6:59am UTC](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/11 "2017-12-07T06:59:20Z")
</div>
_In reply to [srbeeram](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/10):_
**Post date:** [December 7, 2017, 10:51am UTC](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/12 "2017-12-07T10:51:12Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/11):_
Hi Dave, could you please clarify the following. in the following code from above example, are d1 ,d2 and d3 get created and assigned with default value of 0 before super.new(d3) , and assigned with the values d1=4, d2=c2 and d3=6 immediately after super.new(d3) in the D class constructor.
```verilog
class D extends C;
   int d1 = 4;
   int d2 = c2;
   int d3 = 6;
function new;
   super.new(d3);
I am expecting that way as I am getting the value of d3 as 6 in the below code. could you please clarify.
```verilog
class C;
   int c1 = 1;
   int c2 = 1;
   int c3 = 1;
   c2 = 2;
   c3 = a;
class D extends C;
   int d1 = 4;
   int d2 = c2;
   int d3 = 6;
function new;
   super.new(d3);
   $display("value of d3 %d",d3);
D d1=new();
**Post date:** [December 7, 2017, 4:14pm UTC](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/13 "2017-12-07T16:14:21Z")
</div>
_In reply to [srbeeram](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/12):_
The explanation is posted [above](https://verificationacademy.com/forums/systemverilog/question-inheritance-sv#reply-64750).
**Post date:** [December 7, 2017, 4:42pm UTC](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/14 "2017-12-07T16:42:20Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/question-on-inheritance-in-sv/33787/13):_
ok Got it. Thanks.
