# Q: on code coverage and functional coverage?
**URL:** <https://verificationacademy.com/forums/t/q-on-code-coverage-and-functional-coverage/36861>\
**Category:** SystemVerilog\
**Tags:** coverage-system-verilog-cover-bins, SystemVerilog\
**Created:** [November 27, 2019, 6:44pm UTC](https://verificationacademy.com/forums/t/q-on-code-coverage-and-functional-coverage/36861 "2019-11-27T18:44:52Z")\
**Showing post:** 4
**Author:** ![Rahulkumar2](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/rahulkumar2/32/3675_2.png) [@Rahulkumar2](https://verificationacademy.com/forums/u/Rahulkumar2)\
**Post date:** [November 28, 2019, 6:20pm UTC](https://verificationacademy.com/forums/t/q-on-code-coverage-and-functional-coverage/36861/4 "2019-11-28T18:20:58Z")
**1) If my code coverage is 100% and functional coverage is 80% . How to improve functional coverage?**
 → you don’t have test cases which are covering the functional scenarios which are coded in functional coverage. so you need to create the test cases which can exercise those functional scenarios.
**2) If my functional coverage is 100% and code coverage is 80%. How to improve code coverage?**
 → There is hole in your functional coverage. you don’t have test cases which exercise those code. So write the test cases which exercise those code and modify the functional coverage code to add those missing functional scenarios.
 → There is also chance that design having the dead code.
**3)If both code coverage and functional coverage is 100% . Is my verification is successfully completed?**
 → No!!! Do multiple reviews of the test cases and functional coverage.
 → Do review the waveform of few test cases to check test is doing as expected.
 → Do read the specification multiple time and check that there is functional coverage for each functional scenario.
_[View the full topic](https://verificationacademy.com/forums/t/q-on-code-coverage-and-functional-coverage/36861)._
