# Put a transaction into analysis fifo
**URL:** <https://verificationacademy.com/forums/t/put-a-transaction-into-analysis-fifo/42786>\
**Tags:** UVM, UVM-UVM\_TLM\_ANALYSIS\_FIFO\
**Created:** [December 3, 2023, 12:33pm UTC](https://verificationacademy.com/forums/t/put-a-transaction-into-analysis-fifo/42786 "2023-12-03T12:33:15Z")\
**Showing post:** 4
**Post date:** [December 6, 2023, 2:02pm UTC](https://verificationacademy.com/forums/t/put-a-transaction-into-analysis-fifo/42786/4 "2023-12-06T14:02:42Z")
_In reply to [m\_v](https://verificationacademy.com/forums/t/put-a-transaction-into-analysis-fifo/42786/3):_
You should never extend the uvm\_sequencer class. The reason for this is that the run\_phase() in the base uvm\_sequencer is required to execute for proper functionality.
You should use a typedef:
```verilog
typedef uvm_sequencer#(spi_transaction) spi_slave_sequencer;
_[View the full topic](https://verificationacademy.com/forums/t/put-a-transaction-into-analysis-fifo/42786)._
