# Public event in UVM
**URL:** <https://verificationacademy.com/forums/t/public-event-in-uvm/39183>\
**Category:** UVM\
**Tags:** UVM, uvm-events-synchronisation\
**Created:** [June 14, 2021, 1:10am UTC](https://verificationacademy.com/forums/t/public-event-in-uvm/39183 "2021-06-14T01:10:44Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![verific\_engi](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/v/c5a1d2/32.png) [@verific\_engi](https://verificationacademy.com/forums/u/verific_engi)\
**Post date:** [June 14, 2021, 1:10am UTC](https://verificationacademy.com/forums/t/public-event-in-uvm/39183/1 "2021-06-14T01:10:44Z")
</div>
Hello
I want to trigger an event in test cases and wait for it in another class. Is there a concept of public/global event declaration in SV to be used to implement this method. I have tried to go through different examples they all are focused on the same class triggers.
**Author:** ![bdreku](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/bdreku/32/4520_2.png) [@bdreku](https://verificationacademy.com/forums/u/bdreku)\
**Post date:** [June 14, 2021, 3:51am UTC](https://verificationacademy.com/forums/t/public-event-in-uvm/39183/2 "2021-06-14T03:51:33Z")
</div>
_In reply to [verific\_engi](https://verificationacademy.com/forums/t/public-event-in-uvm/39183):_
If you have defined an event in testcase then it’s scope is limited to testcase itself.
You have to pass this event to another class in order to wait there.
**Post date:** [June 14, 2021, 6:11am UTC](https://verificationacademy.com/forums/t/public-event-in-uvm/39183/3 "2021-06-14T06:11:38Z")
</div>
_In reply to [verific\_engi](https://verificationacademy.com/forums/t/public-event-in-uvm/39183/2):_
Use uvm\_event\_pool [UVM\_Event\_Pool | Verification Academy](https://verificationacademy.com/forums/uvm/uvmeventpool)
**Post date:** [June 14, 2021, 12:38pm UTC](https://verificationacademy.com/forums/t/public-event-in-uvm/39183/4 "2021-06-14T12:38:50Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/public-event-in-uvm/39183/3):_
Thanks, Dave for pointing out at right source.
