# Problem related to connection of two interfaces through configuration
**URL:** <https://verificationacademy.com/forums/t/problem-related-to-connection-of-two-interfaces-through-configuration/30609>\
**Tags:** virtual-interface, UVM, configuration, config\_db\
**Created:** [May 5, 2015, 7:44am UTC](https://verificationacademy.com/forums/t/problem-related-to-connection-of-two-interfaces-through-configuration/30609 "2015-05-05T07:44:20Z")\
**Showing post:** 2
**Author:** ![karandeepsingh](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/k/e79b87/32.png) [@karandeepsingh](https://verificationacademy.com/forums/u/karandeepsingh)\
**Post date:** [May 6, 2015, 3:59am UTC](https://verificationacademy.com/forums/t/problem-related-to-connection-of-two-interfaces-through-configuration/30609/2 "2015-05-06T03:59:44Z")
Generally we set the virtual interface in config\_db from TB\_TOP (module declaration for TestBench) and it is recommended to keep the all the connections to DUT/Interfaces there.
You can make any connection you want there and set the interfaces in config\_db
Better you can take any example for understanding it, my personal recommendations try UVM\_COOKBOOK from Mentor
_[View the full topic](https://verificationacademy.com/forums/t/problem-related-to-connection-of-two-interfaces-through-configuration/30609)._
