# Passing Comparator Results or Checked Variable Upstream
**URL:** <https://verificationacademy.com/forums/t/passing-comparator-results-or-checked-variable-upstream/36536>\
**Category:** UVM\
**Tags:** UVM, comparator, scoreboard\
**Created:** [September 12, 2019, 11:37pm UTC](https://verificationacademy.com/forums/t/passing-comparator-results-or-checked-variable-upstream/36536 "2019-09-12T23:37:19Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![polyengineer13](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/polyengineer13/32/1069_2.png) [@polyengineer13](https://verificationacademy.com/forums/u/polyengineer13)\
**Post date:** [September 12, 2019, 11:37pm UTC](https://verificationacademy.com/forums/t/passing-comparator-results-or-checked-variable-upstream/36536/1 "2019-09-12T23:37:19Z")
</div>
Trying to determine if there is a way to pass comparator matches and mismatches from a lower-level agent’s scoreboard to the overall testbench environment’s scoreboard.
In that way when a test is ran, all checked variables or comparator matches/mismatches are funneled up to the top.
For example, I’m envisioning in my top scoreboard\_c that my report\_phase can gather the comparator results from any agent that ran a comparison.
```verilog
function void scoreboard_c::report_phase(uvm_phase phase);
  int checked;
  `uvm_info(name,$sformatf("Reporting scoreboard information...\n%s", this.sprint()), UVM_LOW)
  //add results of lower level comparators to number of checked
  top.checked += tb_env_h.env1_h.comparator_h.m_matches + env1_h.comparator_h.m_mismatches;
  `uvm_info(get_type_name(), $sformatf("Matches: %0d", tb_env_h.env1_h.comparator_h.m_matches), UVM_LOW)
  `uvm_info(get_type_name(), $sformatf("Mismatches: %0d", env1_h.comparator_h.m_mismatches), UVM_LOW)
  if (top.checked == 0)
    `uvm_error(name, "No Transactions Processed.");
  if (env1_h.comparator_h.m_mismatches > 0)
    `uvm_error(name, "Compare Failed");
endfunction : report_phase
**Post date:** [September 13, 2019, 4:51am UTC](https://verificationacademy.com/forums/t/passing-comparator-results-or-checked-variable-upstream/36536/2 "2019-09-13T04:51:25Z")
</div>
_In reply to [solosys](https://verificationacademy.com/forums/t/passing-comparator-results-or-checked-variable-upstream/36536):_
The extract/check/report\_phases are all executed bottom-up, so you can use that information to help propagate totals up. Even better would be to separate the checking to the check\_phase.
**Post date:** [September 13, 2019, 6:59am UTC](https://verificationacademy.com/forums/t/passing-comparator-results-or-checked-variable-upstream/36536/3 "2019-09-13T06:59:38Z")
</div>
_In reply to [solosys](https://verificationacademy.com/forums/t/passing-comparator-results-or-checked-variable-upstream/36536/2):_
```verilog
int checked;
The question is what is the benefit of this approach. Finally you want to see all matches/mismatches somewhere in 1 log-file. This can be done from any level.
In your approach you can pass the lower-level matches/mismatches through the config\_db to the test.
**Post date:** [September 13, 2019, 5:02pm UTC](https://verificationacademy.com/forums/t/passing-comparator-results-or-checked-variable-upstream/36536/4 "2019-09-13T17:02:30Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/passing-comparator-results-or-checked-variable-upstream/36536/3):_
So I guess that’s more of my question of what the proper syntax/mechanism to propagate up. Attempting something like the code above doesn’t work because it seems like the scoreboard isn’t “aware” of the testbench hierarchy.
i.e. top.checked += tb\_env\_h.env1\_h.comparator\_h.m\_matches returns an error
the actual comparator is actually a few more levels down.
more like tb\_env\_h.env1\_h.env1\_h.scoreboard\_h.comparator\_h
**Post date:** [September 13, 2019, 5:04pm UTC](https://verificationacademy.com/forums/t/passing-comparator-results-or-checked-variable-upstream/36536/5 "2019-09-13T17:04:07Z")
</div>
_In reply to [chr\_sue](https://verificationacademy.com/forums/t/passing-comparator-results-or-checked-variable-upstream/36536/4):_
chr\_sue,
Wouldn’t this require a change to the lower level egent’s code? The scoreboard is part of a UVC, of which I do not wish to modify.
**Post date:** [September 14, 2019, 7:36am UTC](https://verificationacademy.com/forums/t/passing-comparator-results-or-checked-variable-upstream/36536/6 "2019-09-14T07:36:16Z")
</div>
_In reply to [solosys](https://verificationacademy.com/forums/t/passing-comparator-results-or-checked-variable-upstream/36536/5):_
Yes it’s true you had to modify this UVC code. But you have to do this in any way, except the compare results are passed to the config\_db and you can retrieve them from a higher level.
**Post date:** [September 20, 2019, 12:13pm UTC](https://verificationacademy.com/forums/t/passing-comparator-results-or-checked-variable-upstream/36536/7 "2019-09-20T12:13:05Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/passing-comparator-results-or-checked-variable-upstream/36536/6):_
Are they any examples on how to propagate the comparator matche/mismatches upstream?
