# Pass array to a function
**URL:** <https://verificationacademy.com/forums/t/pass-array-to-a-function/35469>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, systemverilog-Arrays\
**Created:** [December 14, 2018, 3:43pm UTC](https://verificationacademy.com/forums/t/pass-array-to-a-function/35469 "2018-12-14T15:43:41Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![verif\_learner1](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/v/7993a0/32.png) [@verif\_learner1](https://verificationacademy.com/forums/u/verif_learner1)\
**Post date:** [December 14, 2018, 3:43pm UTC](https://verificationacademy.com/forums/t/pass-array-to-a-function/35469/1 "2018-12-14T15:43:41Z")
</div>
I am passing an array to a function. I don’t know the size of the array that a caller will use.
Here is what I am observing:
case 1) when I use like below, I see an error “Illegal ref port connection”
```verilog
function func1 (ref int a []);
case 2) when I use this below, where I remove the ref, I don’t see an error
```verilog
function func1 (int a []);
case 3) when I use like below, where I specify the size of the array, I don’t see an error
```verilog
function func1 (ref int a [5]);
One full example is shown below:
```verilog
module x;
    $display ("%p", a);
    int a [5] = {1,2,3,4,5};
    func1(a);
**Post date:** [December 14, 2018, 4:27pm UTC](https://verificationacademy.com/forums/t/pass-array-to-a-function/35469/2 "2018-12-14T16:27:57Z")
</div>
_In reply to [verif\_learner](https://verificationacademy.com/forums/t/pass-array-to-a-function/35469):_
There are many more restrictions when using pass by reference direction. The formal and actual argument types must match exactly. A fixed sized array is not the same type as a dynamic array. Another restriction your tool did not catch is you can only use pass by reference with functions/tasks that have an automatic lifetime. [See this link](https://verificationacademy.com/forums/systemverilog/what-meant-reference-argument-must-be-automatic#reply-41381).
Also, you are declaring your function without an explicit return type. The Verilog implicit default is 1-bit return value. Use ‘function void’
**Post date:** [December 14, 2018, 5:33pm UTC](https://verificationacademy.com/forums/t/pass-array-to-a-function/35469/3 "2018-12-14T17:33:02Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/pass-array-to-a-function/35469/2):_
> _In reply to [verif\_learner](https://verificationacademy.com/forums/t/pass-array-to-a-function/35469/2):_
ok. So, what is the option available if I want to pass an array as an argument to a function if I do not know the size of the array. I assume this is a very common issue in verification.
For example, if I am passing a array that contains packet data to the function, most likely I will not know the size of the packet at all.
**Post date:** [December 14, 2018, 7:02pm UTC](https://verificationacademy.com/forums/t/pass-array-to-a-function/35469/4 "2018-12-14T19:02:04Z")
</div>
_In reply to [verif\_learner](https://verificationacademy.com/forums/t/pass-array-to-a-function/35469/3):_
Usually, the packet is a class object with an arrays as a member. You just pass the object’s handle as an input to the function.
If you make sure you always use a dynamic array, you can pass an array by reference.
```verilog
module x;
    $display ("%p", a);
    int a [];
    a = {1,2,3,4,5};
    func1(a);
**Post date:** [December 15, 2018, 4:21pm UTC](https://verificationacademy.com/forums/t/pass-array-to-a-function/35469/5 "2018-12-15T16:21:29Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/pass-array-to-a-function/35469/4):_
> _In reply to [verif\_learner](https://verificationacademy.com/forums/t/pass-array-to-a-function/35469/4):_
```verilog
module x;
$display ("%p", a);
int a [];
a = {1,2,3,4,5};
func1(a);
Dave,
I am going through LRM section 7.7.
This is what it says,
> A subroutine that accepts a dynamic array or queue can be passed a dynamic array, queue, or fixed-size array of a compatible type.
> For example, the declaration
> task t ( string arr );
> declares a task that accepts one argument, a dynamic array of strings. This task can accept any onedimensional unpacked array of strings or any one-dimensional dynamic array or queue of strings.
I am interpreting this as if the formal argument to the function is dynamic array then one can call this function with another dynamic array.
Am I interpreting something incorrectly?
**Post date:** [December 15, 2018, 4:46pm UTC](https://verificationacademy.com/forums/t/pass-array-to-a-function/35469/6 "2018-12-15T16:46:11Z")
</div>
_In reply to [verif\_learner](https://verificationacademy.com/forums/t/pass-array-to-a-function/35469/5):_
Yes, I made a mistake in my example. Now they are both dynamic arrays. BTW, section 7.7 discusses the rules for passing arrays by value. Passing by references has more strict rules.
