# PACKAGE doubt
**URL:** <https://verificationacademy.com/forums/t/package-doubt/29126>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, Package\
**Created:** [January 31, 2014, 7:35pm UTC](https://verificationacademy.com/forums/t/package-doubt/29126 "2014-01-31T19:35:04Z")\
**Showing post:** 3
**Author:** ![logie](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/l/74df32/32.png) [@logie](https://verificationacademy.com/forums/u/logie)\
**Post date:** [February 1, 2014, 7:41am UTC](https://verificationacademy.com/forums/t/package-doubt/29126/3 "2014-02-01T07:41:37Z")
You have included generator\_class.sv twice; once in the program file and once in the driver class. Both these are also defined in the same root scope. Hence you are seeing multiple definitions.
As Dave (dave\_59) suggest you need to use packages. You would need to define generator class inside a package and import the package in the scope where you need it. This will eliminate your symbol clashes.
```verilog
package MyPackage;
   class generator_t;
endpackage
Import using
```verilog
import MyPackage::*;
in any scope;
Refer to Section 26 of the 1800-2012 SystemVerilog reference manual for detailed instructions.
_[View the full topic](https://verificationacademy.com/forums/t/package-doubt/29126)._
