# OVM Sample Called, Still Yielding 0% Coverage
**URL:** <https://verificationacademy.com/forums/t/ovm-sample-called-still-yielding-0-coverage/31999>\
**Category:** Coverage\
**Tags:** OVM-coverage, Coverage\
**Created:** [June 29, 2016, 10:57pm UTC](https://verificationacademy.com/forums/t/ovm-sample-called-still-yielding-0-coverage/31999 "2016-06-29T22:57:58Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![rachel.greenlee](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/r/b19c9b/32.png) [@rachel.greenlee](https://verificationacademy.com/forums/u/rachel.greenlee)\
**Post date:** [June 29, 2016, 10:57pm UTC](https://verificationacademy.com/forums/t/ovm-sample-called-still-yielding-0-coverage/31999/1 "2016-06-29T22:57:58Z")
</div>
Hi, I am working on a coverage class in OVM. I have a covergroup, and an array (a hex value), and I only want to run a sample on my covergroup when the value of the array is greater than zero.
I have print statements in my if statement, so I know that I am hitting the if statement (data is getting set to the array). However, my covergroup has 0% coverage, which I don’t understand because I feel that the sample() call has to be happening since I’m hitting the if. Is there any way you can be sampling a covergroup and still get 0% coverage for the covergroup?
Also, note that when I did not have the sample() statement inside the if, I had 100% coverage. But whenever I encase it in the if, I cannot get it to have any coverage at all.
I simplified this as much as I could for this example, so this probably isn’t 100% syntactically correct, but here is the general idea:
```verilog
class cov_example extends ovm_component;
    bit coverage_enable = 1;
    bit [63:0] array1;
    covergroup example_cg;
        option.per_instance = 1; // Will indicate that coverage is present, yielding coverage results
        array1 : coverpoint array1 {
            bins x = {array1[0]};
            bins none = default;
    endgroup : example_cg
    `ovm_component_utils_begin(cov_example)
        `ovm_field_int(coverage_enable, OVM_DEFAULT)
    `ovm_component_utils_end
    function new (string name, ovm_component parent);
        super.new(name, parent);
        example_cg = new();
        example_cg.set_inst_name({get_full_name(), ".example_cg"});
    endfunction : new
        super.build();
    endfunction : build
    function void write(ovm_sequence_item pkt);
	someFunction(); // Assume that this is a function that sets array1 to some nonzero value.
        if (coverage_enable) begin
		if( array1 > 0)begin
               example_cg.sample();
endclass : cov_example
**Post date:** [June 30, 2016, 3:54pm UTC](https://verificationacademy.com/forums/t/ovm-sample-called-still-yielding-0-coverage/31999/2 "2016-06-30T15:54:09Z")
</div>
_In reply to [rachel.greenlee](https://verificationacademy.com/forums/t/ovm-sample-called-still-yielding-0-coverage/31999):_
What is the intended meaning of
```verilog
Because array[0] == 0 when the convergroup gets constructed, this is equivalent to
```verilog
bins x = {0};
which I’m sure is not what you intended. If you only callsample() when array is non-zero, you will get 0% coverage.
**Post date:** [June 30, 2016, 4:09pm UTC](https://verificationacademy.com/forums/t/ovm-sample-called-still-yielding-0-coverage/31999/3 "2016-06-30T16:09:40Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/ovm-sample-called-still-yielding-0-coverage/31999/2):_
This is my first time to make a coverage class, and I think there are gaps in my understanding as to what occurs when I call sample(). My intention is to, like I said, set the bin only when the data is \> 0. Could I do something like
```verilog
 bins x = {array1};
and achieve my desired results?
**Post date:** [June 30, 2016, 4:20pm UTC](https://verificationacademy.com/forums/t/ovm-sample-called-still-yielding-0-coverage/31999/4 "2016-06-30T16:20:05Z")
</div>
_In reply to [rachel.greenlee](https://verificationacademy.com/forums/t/ovm-sample-called-still-yielding-0-coverage/31999/3):_
A coverpoint defines an expression to be sampled when sample() gets called. bin values are defined when the covergroup gets constructed. Each time you call sample(), the value of the sampled coverpoint expression gets compared with set of bin values defined at construction. If the values match, the bin is set as “covered”.
It seems what you really want is
```verilog
        option.per_instance = 1; // set this if there will be multiple instance of this class
        array_is_nonzero : coverpoint array1 >0 {
            bins x = {1}; // will be hit if array1 > 0 is true
**Post date:** [July 7, 2016, 3:33pm UTC](https://verificationacademy.com/forums/t/ovm-sample-called-still-yielding-0-coverage/31999/5 "2016-07-07T15:33:31Z")
</div>
Ok thank you! I actually ended up figuring this out. What I did was sample it no matter what, and check in the covergroups, but a slightly different way than you showed me:
```verilog
            bins x = {[1:$]};
            bins none = {0};
