# Ovm\_comparer doesn't print negative values
**URL:** <https://verificationacademy.com/forums/t/ovm-comparer-doesnt-print-negative-values/29442>\
**Category:** OVM\
**Tags:** signed, OVM, complement, negative, ovm\_comparer\
**Created:** [May 8, 2014, 7:16am UTC](https://verificationacademy.com/forums/t/ovm-comparer-doesnt-print-negative-values/29442 "2014-05-08T07:16:20Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![vman\_joe](https://verificationacademy.com/forums/letter_avatar_proxy/v4/letter/v/a87d85/32.png) [@vman\_joe](https://verificationacademy.com/forums/u/vman_joe)\
**Post date:** [May 8, 2014, 7:16am UTC](https://verificationacademy.com/forums/t/ovm-comparer-doesnt-print-negative-values/29442/1 "2014-05-08T07:16:20Z")
</div>
Because I couldn’t manage the ovm\_comparer to print negative values of object members, I’ve tested the following minimal example.
```verilog
my_comparer.compare_field_int("negative value test",3,-5,4,OVM_DEC);
I get the following unexpected output from Questa.
# OVM\_INFO @ 3220: reporter [MISCMP] Miscompare for negative value test: lhs = 3 : rhs = 11
Two’s complement is always printed for negative values, what I’m doing wrong?
BR,
Steffen
**Post date:** [May 8, 2014, 3:13pm UTC](https://verificationacademy.com/forums/t/ovm-comparer-doesnt-print-negative-values/29442/2 "2014-05-08T15:13:05Z")
</div>
The problem is that some of the people that wrote the OVM/UVM have no idea what an **int** is. Sometimes it is a 4K bit unsigned vector, sometimes its a 64-bit unsigned integer. It is never a 32-bit signed integer, like it is supposed to be.
You options are:
1. Live wit h it.
2. use compare\_field\_real
3. override the the ovm\_comparer class
4. write your own compare method.
**Post date:** [May 9, 2014, 9:39am UTC](https://verificationacademy.com/forums/t/ovm-comparer-doesnt-print-negative-values/29442/3 "2014-05-09T09:39:19Z")
</div>
_In reply to [dave\_59](https://verificationacademy.com/forums/t/ovm-comparer-doesnt-print-negative-values/29442/2):_
Probably the reason why the case OVM\_UNSIGNED isn’t implemented for the compare\_field() and compare\_field\_int() functions in ovm\_comparer.
Thx.
