# Override configuration value in sequence
**URL:** <https://verificationacademy.com/forums/t/override-configuration-value-in-sequence/36740>\
**Tags:** get-set, UVM, configuration, config\_db\
**Created:** [October 30, 2019, 5:38am UTC](https://verificationacademy.com/forums/t/override-configuration-value-in-sequence/36740 "2019-10-30T05:38:14Z")\
**Showing post:** 2
**Post date:** [October 31, 2019, 7:00pm UTC](https://verificationacademy.com/forums/t/override-configuration-value-in-sequence/36740/2 "2019-10-31T19:00:08Z")
_In reply to [Jessita J](https://verificationacademy.com/forums/t/override-configuration-value-in-sequence/36740):_
You are doing strange things. The sequence does not have a position in the hierarchy of your testbench. Commonly the test is used to configure your testbench. The agent belongs to the hierarchy.
A sequence should run on your testbench.
_[View the full topic](https://verificationacademy.com/forums/t/override-configuration-value-in-sequence/36740)._
