# Next Cycle Implication operator does not work
**URL:** <https://verificationacademy.com/forums/t/next-cycle-implication-operator-does-not-work/41787>\
**Category:** SystemVerilog\
**Tags:** SystemVerilog, assertion, next\_cycle\_implication\_operator\
**Created:** [June 9, 2023, 8:45am UTC](https://verificationacademy.com/forums/t/next-cycle-implication-operator-does-not-work/41787 "2023-06-09T08:45:20Z")\
**Showing post:** 6
**Author:** ![user49](https://verificationacademy.com/forums/user_avatar/verificationacademy.com/user49/32/1084_2.png) [@user49](https://verificationacademy.com/forums/u/user49)\
**Post date:** [June 10, 2023, 3:04am UTC](https://verificationacademy.com/forums/t/next-cycle-implication-operator-does-not-work/41787/6 "2023-06-10T03:04:28Z")
_In reply to [UVM\_LOVE](https://verificationacademy.com/forums/t/next-cycle-implication-operator-does-not-work/41787/5):_
…"SVA testbench must be conducted on non-blocking domain. "
[Ben] Not quite. However, typically, signals are assigned nonblocking and occur in the NBA region. Doing a #10 a=1; with posedge(clk) changing at t is same time when “a” changes can be problematic. It is also not stylist, though it should work; this is because within a time step signals used in an assertin are sampled in the Preponed region with the value just before the time step. What would be better is to do something like
@(posedge clk) a=1; // or a \<=1;
Assertion sample signals in the Preponed region
See my paper 3) Understanding Assertion Processing Within a Time Step (Horizons Feb 27, 2023 issue)
> **[Understanding\_assertion\_processing.pdf](https://systemverilog.us/vf/Understanding_assertion_processing.pdf)**
> 641.07 KB
This paper goes into detail about how evaluation regions should be handled by a simulator as described in the SystemVerilog LRM; this should give you a better understanding of how assertions work.
```verilog
// I do the following:
    $dumpfile("dump.vcd"); $dumpvars;
    bit v_a, v_b, v_err;
    repeat (200) begin
      @(posedge clk);
      if (!randomize(v_a, v_b, v_err) with {
        a dist {1'b1 := 1, 1'b0 := 1}; // ***** CAN USE signal a
        // a changes in the Active region ************ OK
        v_b dist {1'b1 := 1, 1'b0 := 2};
        v_err dist {1'b1 := 1, 1'b0 := 15};
      }) `uvm_error("MYERR", "This is a randomize error");
      if(v_err==0) b<=v_b; else b<=!v_b;
       // b changes in the NBA region ****************
    $finish;
_[View the full topic](https://verificationacademy.com/forums/t/next-cycle-implication-operator-does-not-work/41787)._
